Private Messaging - Help!
  • Airborne01
    • Mar 2021
    • 4360
    • Steve
    • Essex
    Greetings O Cognoscenti! I can foresee the need to invite people to engage in a brief PM in the near future but, having the tech skills of an Andalusian Aardvark, I have no idea how to set this up. I would be grateful if somebody could explain, preferably in words of one syllable, the process. Many thanks!
    • 16293
    Hi Steve
    I find a post by the person I want to pm. Click on the avatar/name. A box will appear and at the bottom it says "start conversation". Click that and away you go.
    • Airborne01
      • Mar 2021
      • 4360
      • Steve
      • Essex
      Thanks Jim, this Bear of Very Little Brain is eternally indebted!
      • adt70hk
        • Sep 2019
        • 10551
        Alternatively, click on the conversations icon (envelope) then select 'start a new conversation' and start to type in the username of the forum member. As you start to type it will bring up the available options until we find the one you want.
        hope that helps.
          • 16293
          Hi Andrew
          You learn something new everyday :thumb2:
          • Airborne01
            • Mar 2021
            • 4360
            • Steve
            • Essex
            Thanks Andrew
            • PaulTRose
              • Jun 2013
              • 7244
              • Tattooine
              Andalusian Aardvark?.........wernt they a prog rock band from the early 80s? :smiling6:
              Per Ardua
              • Airborne01
                • Mar 2021
                • 4360
                • Steve
                • Essex
                I saw them perform at the local Derby & Joan club - bit too noisy for me - nearly broke my hearing aid!
                  Originally posted by Jim R
                  Hi Steve
                  I s this then private Jim between the two persons.
                  I had a post removed as what I thought was private was open to any one to read.
                    • 19130
                    Yes it is Laurie. Others can only read it if you invite them.
                      • 16293
                      Hi Laurie
                      Yes. The message is only between the participants in the conversation. If I were to pm you only we could see it. We could have a bigger group if the message instigator chose to so do.
                        Hi Laurie
                        Thanks Tim. I knew there would be some one on here bright than I am.
                          Hi Laurie
                          Thanks Jim. Wow two people brighter than I am. Splendid.
                            • 19130
                            Don’t flatter me buddy, I just know where the button is LOL :tongue-out3:
                              Boy am I not Tim. I am comparing you to me. My IQ is 220 very low in my standards.
