Latest Acquisitions (2022)
That makes sense now Peter. When we lived on an island in the Outer Hebrides RM charged the standard rate whereas ordering from a supplier who used a courier was often prohibitively expensive.
We may have gripes with RM but if they weren't there people living in very rural, way out places would be at the mercy of very high costs.Comment
https://www.tnt.com/express/en_gc/si...-aerosols.html <<<< even couriers have rulesMy point about John not being allowed to send the Premi-air Reamer by Royal Mail was that the process of delivery is the same for Royal Mail and for couriers. Surely they are both covered by the same rules. It seems unfair if couriers are governed by less strict rules.
JimComment
I think it’s a legal issue more than a business model Pete. Restricted Hazmat items are simply not allowed in the regular postal stream.
Courier firms run an on demand system, not a timetabled service. This enables them to run with drivers and handlers that are appropriately trained, the vans clearly marked, and the correct spill kits to be carried.
I know the dispatchers at my old place of work had to be named individuals. They had to be listed in our written procedures and had to undergo regular refresher courses so they could dispatch anything contained in the hazmat listings. Courier firms probably run similar systems.Comment
Back on topic…….
A few things for my mosquito in the current GB…
Etch set and mask set…..
Decal set, obviously I’ll be using the mossy decals not the others…..
And a lovel set of resin exhausts. Great aren’t they……trouble is, if I use them in the build they will be completely invisible :flushed: :flushed:Comment
Very nice stuff there Tim. I'm still trying to find canopy masks for my 1/48 Revell kit. No one at the show had any and Eduard etch stuff was also absent on the stands.......
AllenLife's to short to be a sheep...Comment
Cheers Jim. Yep, hollow ends is exactly why I bought them…….have a look at the mossy image in the decals and the box art though. They have anti flash covers so can’t be seen….Comment
Canopy masks save so much time I always find them worth the effort. Not sure if Eduard or Montex do them for the Revell kit Allen. The Tamiya set might work for it though? They are the same scale so should be pretty much identical. Being in the EU you should be able to order direct from the manufacture :thumb2:Comment
Probably standard fittment on anything used for night ops Jim. Exhaust flash would both blind the crew and give away the aircraft position to the enemy…..not sure where to get definitive info though.Comment
Keep an eye out for that orange packaging in an upcoming post.....Back on topic…….
[ATTACH=CONFIG]n1179723[/ATTACH]
[ATTACH=CONFIG]n1179724[/ATTACH]
[ATTACH=CONFIG]n1179725[/ATTACH]
Got this yesterday, from a kind friend with a 3D printer:
[ATTACH]457720[/ATTACH]
Hubs for the discs in the T1E1 mine roller I’m building, because the parts in the conversion set are not up to scratch at all.Comment
