What Solution for Ultrasonic Cleaner
  • slupanter
    • Jun 2010
    • 554
    Hey all,
    Question time! Queue the theme! ( QUESTION TIME THEME TUNE - YouTube )
    I spray Lacquer based paint (Tamiya, Mr H, MRP), what solution is best used in my ultrasonic cleaner?
    I have been using IPA99% but I am wondering if there is something out there that is as good but kinder on the nose and the AB seals.
    • 19130
    I would try dilute washing up liquid first Alexander. Ultrasonic baths are quite aggressive so you don’t really need to solvate the paint.
      • 19130
      I would also recommend warm water, and suspend the item. If you lay it on the bottom of the tank the area in contact with the bath won’t experience impact with the cavitation bubbles produced by the soniprobe. We used to clean lab kit in them back in the days before disposable technology. They were fantastic for cleaning coins just using dish soap as well.
      • slupanter
        • Jun 2010
        • 554
        Hi Tim, how should I suspend the items?
          • 19130
          We just used a wire basket and moved them around every couple of minutes.
            • 18302
            Stainless steel tea strainer should do the trick.
            • slupanter
              • Jun 2010
              • 554
              I have just stolen Louise’s baking sieve
              • rickoshea52
                • Dec 2011
                • 4081
                • Rick
                Mine has a plastic basket that lifts in/out much like a deep fat fryer arrangement.
                • slupanter
                  • Jun 2010
                  • 554
                  I have misplaced mine
                    • 19130
                    That sounds ideal. Ours was like a stainless steel chip basket.
                      • 16295
                      Although I don't use mine a lot it is very useful when the airbrush needs a deep clean. Even if I've used enamels or lacquers I find warm water and washing up liquid works well. Mine has a plastic basket to put the bits in.
                        Use mine with VMS ab cleaner, some times just water and fairy when cleaning glasses !
                        Always use the basket .
                        • stillp
                          • 8308
                          • Pete
                          • Rugby
                          I bought some jewellery cleaner concentrate when I bought my ultrasonic. Tried it out on the black mesh strap of a Skagen watch, and it stripped the blacking off! I just use washing-up liquid in the water now.
                            • 19130
                            They are aggressive. You basically hit the surface with very high energy solvent bubbles at temperatures of around 5000K. The bubbles are so small that the mechanical effect is limited to the surface though.
                            • PaulTRose
                              • Jun 2013
                              • 7249
                              • Tattooine
                              always used warm water and a decent brand of washing up liquid, works for me
                              Per Ardua
