Other options
  • benjamin da scalemodeler
    • Mar 2022
    • 38
    Other options
    Hey, i was looking at eduards extraparts for Mosquito (tamiya) when i saw they dont sell it. Can i use the part for airfix or is it other brands that can offer me extra parts like eduard?
  • Gary MacKenzie
    SMF Supporter
    • 1059
    • Gary
    • Forres , Moray , Scotland
    Which Tamiya Mosquito?
    Scalemates lists the upgrades for Tamiya 1/48th @ https://www.scalemates.com/kits/tami...140731/related
    Scalemates lists the upgrades for Tamiya 1/72nd @ https://www.scalemates.com/kits/tami...121605/related
    If the kits are truly to scale the parts from the upgrade sets should all fit, but no guarantees.
    I have certainly used PE upgrades meant for Tamiya on Dragon models and for Dragon models on Tamiya, but I tend to only use some pe.
      • Mar 2022
      • 38
      Jeg was thinking about the 1/72. But thx for the links
        • Mar 2022
        • 38
        But is there any links that can give me a good looking kocpit. Or can i find all i need in that link?
          • 16294
          Hi Ben
          Welcome to the forum.
          I think Aires do a cockpit kit for the 1/72 Mosquito # 7067.
            • Mar 2022
            • 38
            Thx
              • 18302
              it will be fun to do but you wont be seeing any of it when the lid goes on.
                I have no experience with either of the plastic kits or the etched parts for them, but in general: it depends. Some parts will fit fine, others may be too large or too small. It largely depends on the differences between the plastic kits, probably: if, for example, Tamiya has moulded a part slightly too short and Airfix have the same thing slightly too long, then an etched part for the Airfix kit that goes in this location might not fit in the room available on the Tamiya model. The only real way to know, though, is to buy a set and try it … chances are that you can use most or all of the parts intended for an Airfix kit on a Tamiya one, but you may have to do more work to make them fit than you would if you had an Airfix kit in the first place.
