Any advice? (Hanging builds)
  • Del640
    • May 2020
    • 1214
    Just a quick ask...
    I place my builds into glass cabinets, I currently hang the aircraft using both 'sucker' pads and/or adhesive double sided tape from the glass shelves undersides.
    However, both keep failing and aren't 'man enough' to hold even 1/72 scale after a week or so.... glass is thoroughly cleaned prior so I'm at a loss!
    So, anybody with experience of something with a bit more 'umph' about it?
    Thanks in advance,
    Del
  • outrunner
    • Apr 2019
    • 2420
    These might be worth a try as they say they stick to glass.
    Andy.
    • Airborne01
      • Mar 2021
      • 4295
      • Steve
      • Essex
      Rawlbolts perhaps?
      • stillp
        • 8276
        • Pete
        • Rugby
        There are some solutions, used for sticking rear view mirrors to the inside of car windscreens - specialist double-sided tape, or UV-cured CA. Your local windscreen replacement company might give you a small amount to try.
        • Mr Bowcat
          SMF Supporter
          • Dec 2016
          • 4691
          • Bob
          • London
          Probably a bit late now, but for unbuilt kits neodymium magnets glued inside the fuselage, and a small metal plate on top of the shelf above. That way they would hold in place (neo magnets are incredibly strong) but still be removable/re-positional.
          Si vis pacem, para bellum.
