decal fix
  • boatman
    • Nov 2018
    • 14591
    • christopher
    • NORFOLK UK
    #16
    Originally posted by rtfoe
    Chris, you can't use Decal Film when the decal is already on the model. Coat the decals while still on the decal sheet, when dry cut as close to the images as the Decal Film creates a layer of film over the decal. Put your cut pieces in lukewarm water, remove and place on tissue, as soon as the decal moves easily on the backing paper it is ready to slide onto your model.
    The Red Decal Solution is applied after the decal is placed in the model...let it do its wonders until the decal conforms to the surface. Don't touch it as they will look wrinkly at first but will settle flat.
    HI Richard yea i will do what you say on the other 3 seaking decals an cheers for your info as well
    ATB
    chrisb
    • Ancientmariner
      • Feb 2018
      • 867
      #17
      If the decals are on and set why not just spray it with varnish of desired finish?
