Here is the BIG box that landed today...
[ATTACH]39694.vB[/ATTACH]
This box is simply packed with plastic. I will not put on here pictures of all the sprues, just a few examples of the moulding. Overall I find the kit offers excellent well rendered detail with the sprues mostly individually packed. They offer seats with or without moulded seat harnesses, two options for the instrument panel - you can have it molded for painting or in clear plastic with a decal. The wings are articulated and can be raised or lowered, however, there are some parts which if glued to the raised wings means they cannot be lowered.
One criticism some have made is that the kit offers a lot of detail that will never be seen once it is closed up. This is true, but I like that as it offers opportunities for advanced modellers (I am not one of those...) to really have fun with the kit not necessarily having to buy aftermarket parts. Its good to have the choice and I may choose to paint up and include all the unseen material, I may not...
Some detail shots:
[ATTACH]39695.vB[/ATTACH][ATTACH]39696.vB[/ATTACH][ATTACH]39697.vB[/ATTACH][ATTACH]39698.vB[/ATTACH][ATTACH]39699.vB[/ATTACH][ATTACH]39700.vB[/ATTACH][ATTACH]39701.vB[/ATTACH]
The instruction sheet, to me, is most impressive - it reads like an aircraft manual. It contains colour reference photos of the kit construction and some very clear warnings including such as ... 'be careful not to bend during assembly'. There are different views that explain exactly how/here parts should be placed - quite simply a lot of thought and planning went into these. It seems very clear to me and includes a sheet correcting a couple of errors. If only Dragon were half as considerate with their instructions!
[ATTACH]39702.vB[/ATTACH][ATTACH]39703.vB[/ATTACH][ATTACH]39704.vB[/ATTACH][ATTACH]39705.vB[/ATTACH][ATTACH]39706.vB[/ATTACH][ATTACH]39707.vB[/ATTACH][ATTACH]39708.vB[/ATTACH][ATTACH]39709.vB[/ATTACH]
The decal sheet offers two aircraft options which are very similar from USS Intrepid and in this I would have thought they could have done better by offering two much more different schemes. On the positive side they seem good quality and are in register.
[ATTACH]39710.vB[/ATTACH]
Whenever I picture a Spad it is weighted down with a massive load of weapons, absolutely dripping with bombs and rockets. The kits includes only drop tanks which is another criticism. They do, however offer a separate weapons set and there is no way I am going to build a Skyraider without that classic look.... So I invested in the set. It includes pretty much a full range of weapons and some clear guided as to what would go where. You will not end up using a fraction of what is included in the set unless you decide to pose the ordnance around the aircraft. The separate set makes equipping the Spad expensive, but how can you not? Maybe there is room here for some enterprising aftermarket intervention.
[ATTACH]39711.vB[/ATTACH][ATTACH]39712.vB[/ATTACH]
One final criticism - the instructions carry Vallejo paint references and as I am a big fan of Vallejo paints I was pleased with that. But, the main camo colour is 'Gull Grey' and Vallejo were commissioned to produce this colour (Model Air 71130) by ZM for this kit. The colour is simply not available from Vallejo and when I enquired they referred me to ZM. I did ask John to see if he could source this colour for me but no luck. Therefore I assume that this paint is only available in Japan. Maybe that will change but not soon enough for me.... I intend to start this kit in a couple of weeks, as soon as I have finished my Mustang...
I will do this as my first photo build, stage by stage.... Watch this space!!!
Anyway..... to summarise - I am well pleased with what I see and I think that this will build into a large (19 inch wingspan) and very impressive model.
Is it worth the dosh?..... this is far from a cheap kit.
So far so good, yes, I recommend it. But, of course we will see how the build progresses but from some reviews I have read I suspect that my initial impression will hold.
If you like large scale aircraft then I do believe that ZM are the 'up and coming' stars to watch producing 'must builds'....
[ATTACH]43496.IPB[/ATTACH]
[ATTACH]43497.IPB[/ATTACH]
[ATTACH]43498.IPB[/ATTACH]
[ATTACH]43499.IPB[/ATTACH]
[ATTACH]43500.IPB[/ATTACH]
[ATTACH]43501.IPB[/ATTACH]
[ATTACH]43502.IPB[/ATTACH]
[ATTACH]43503.IPB[/ATTACH]
[ATTACH]43504.IPB[/ATTACH]
[ATTACH]43505.IPB[/ATTACH]
[ATTACH]43506.IPB[/ATTACH]
[ATTACH]43507.IPB[/ATTACH]
[ATTACH]43508.IPB[/ATTACH]
[ATTACH]43509.IPB[/ATTACH]
[ATTACH]43510.IPB[/ATTACH]
[ATTACH]43511.IPB[/ATTACH]
[ATTACH]43512.IPB[/ATTACH]
[ATTACH]43513.IPB[/ATTACH]
[ATTACH]43514.IPB[/ATTACH]
Some detail shots:
