CA Glue.
    CA Glue.
    Afternoon all, I normally use a CA from
    but seems a little thick at times, esp as it ages in the bottle. So what does any one recommend please. Thanks John.
    • 16299
    Hi John
    VMS do a range of CA glues. I have a few and find them good. I like VMS stuff. John has a good range in the shop. Worth looking at I think.
    • boatman
      • Nov 2018
      • 14592
      • christopher
      • NORFOLK UK
      WELL John i use cheppo c/a from pound shop an i get three bottles an some very good bits that fit on the ends an it goes down to a very thin tube to controll the flow an i find that very good at stickin bits togeather an my hand onto the work bench Aaaaaaccccchhhhhh
      chrisb
        John,
        I use Loctite Precision Max - I've tried other brands, and I always come back to this..................
        • PaulinKendal
          • Jul 2021
          • 1691
          • Kendal
          Deluxe Materials do CA in three thicknesses - I use all three.
          • stillp
            • 8309
            • Pete
            • Rugby
            Chestnut do a good range.
              • 19130
              Another one for loctite, both the gel type and the one posted by Dave.
              • boatman
                • Nov 2018
                • 14592
                • christopher
                • NORFOLK UK
                John,
                [ATTACH=CONFIG]n1188028[/ATTACH]
                well i used to use this but the prices for this is gettin silly but it is good
                  • 19130
                  Fair enough mate, i only really use it for the odd small bit of PE and sticking the little blokes on their coin bases…..for any bigger joints I use Devcon epoxy which is much more cost effective.
                    Originally posted by Jim R
                    Hi John
                    chrisb
                    John,
                    [ATTACH]467012[/ATTACH]
                    Thanks all, will check these various suggestions out later and then decide and buy.
                    John.
                      Last month, I paid £3.50 for a 10g bottle, which will last me nearly a year!
                        Wow , that's good enough for me then Dave if it lasts that long. Is it the thin type?
                        • Valeron
                          • Jan 2022
                          • 971
                          • Mike
                          • St Albans
                          The problem I've been having work CA glue is that it always dries out once open. I've even tried the putting it in the fridge trick.
                          • boatman
                            • Nov 2018
                            • 14592
                            • christopher
                            • NORFOLK UK
                            WELL Dave here i n shops a 10 gram bottle costs nr £ 7 so how you gettin it that cheap i dont know
                            chrisb
                              This is the thin variety. There are a lot of sellers, prices go up & down -
                              https://www.ebay.co.uk/itm/185185073405?epid=1274431992&hash=item2b1de3f8fd:g :uyMAAOSwl69jaWFo&amdata=enc:AQAHAAAAoJwnCc1yKDWSP 5hY3eQrY9lD0qOUFGtI+H1RTmR8Rk3Jr/3CMJEIyszAfVWDfjnOOG0Kg7bcg4ubS5qGZS2bSu3I9XtDL+KV o1uhXOKcLKqEUC2bvrcvBG43SRxgaK/HKWFprVmxRVsHC31UBOKwxs+abeJhroYnkmO0RTukOH9/V4jQwLjLUF03c5RYSaeqhJJ3ZMinepLgIusQuyq+Epo=|tkp:B k9SR5C_hf-MYQ
                              If Ebay ain'tyour cupof tea, https://www.amazon.co.uk/Loctite-162...2C2680&sr=8-18
