epoxy metal 'Glue' Help please.
  • spanner570
    • 15557
    I clouted my drive's side extended wing mirror yesterday and broke the white metal arm. It's a clean break, so fits nicely back together.
    I only need a temp. repair until I get around to replacing the whole unit.
    Has anyone on here actually used this two part stuff or has used, and can recommend, anything that can 'Weld' white metal?
    Thanks in advance.
    Ron
  • Mark1
    • Apr 2021
    • 4156
    J.b weld.
    • stillp
      • 8137
      • Pete
      • Rugby
      I did a fix on my granddaughter's wing mirror with Araldite two part epoxy. The glue area was pretty small so I epoxied a 3" nail as a splint, then wrapped it with shiny foil tape. It lasted a few months until she sold the car!
      • langy71
        • 1957
        • Chris
        • Nottingham
        agree with Mark1 on this, J.B Weld has served me well when I've needed a bit extra umph from an apoxy.
        I would give it a bit of a rub down with 80 grit sandpaper to give it a good base to grab on to...
          • 18994
          I’ve used 24 hour araldite to fix a hole in an engine casing. It never failed on me while I owned the bike. I’ve found with epoxy that the longer the setting time the stronger the bond. Peter’s idea of using a nail or two as a splint would be prudent as well, especially if you want a functional rather than aesthetic repair..
          • spanner570
            • 15557
            Thanks for the quick and informative response chaps. Much appreciated.
            I knew I could rely on my friends on here to come up trumps....
            Cheers.
            Ron
