SD Card for camera
  • AlanG
    • 6296
    SD Card for camera
    My Sandisk 32Gb SDHC card has developed a crack in the body and is now not going into my digi camera. I don't want to force it and break it totally before i get all my photos off it.
    On looking on evilbay i see loads of micro SD cards with adapters to make the size of the normal SD card. Would these be ok to put into a camera or should i keep searching for a 'correct size' SD card?
  • davecov
    • Jul 2014
    • 882
    • Dave
    • Stow, Scottish Borders
    I had that problem once and now I use exclusively Micro SD cards with or without adaptors. That way I can use the Micro SD cards in my smartphone, dashcam, laptops and PCs without the adaptor and my four Canon digital cameras using the SD Card adaptor.
    DaveCov - Founder of The Airfix Tribute Forum 2006
    • adt70hk
      • Sep 2019
      • 10551
      Yes Al .... That's EXACTLY what I do.....
      • John
        • Mar 2004
        • 4700
        • John
        • Halifax
        I have 2 in my camera with adaptors in, they work fine
        www.scalemodelshop.co.uk
        • AlanG
          • 6296
          Cheers guys. Guess i'll get one then
            • 18302
            I used to have an sd card with built in wi-fi. Could take pictures and send then direct to my lap top. Fantastic. Then they stopped software updates and support for them gutted.
            • Gary MacKenzie
              SMF Supporter
              • 1059
              • Gary
              • Forres , Moray , Scotland
              Works fine in my Canon 70d, allows removal of only micro card if that works for you
              • stillp
                • 8308
                • Pete
                • Rugby
                I can't see the point of using a micro card and adapter - isn't that another connection to go wrong?
                • AlanG
                  • 6296
                  I was only asking as there were loads of these on offer and when i did eventually find the correct size SD card, it was WAY more expensive than the option of a micro SD and adaptor.
                  • stillp
                    • 8308
                    • Pete
                    • Rugby
                    OK, I was just wondering. Have you tried 7Dayshop? https://www.7dayshop.com/categories/...ories/sd-cards
                    • Gary MacKenzie
                      SMF Supporter
                      • 1059
                      • Gary
                      I use the USB connector on the camera to pc, and run Canon image software, but also sometimes remove the card.
