Metal Spitfire Mk 1
  • Modler bob
    • May 2022
    • 277
    Metal Spitfire Mk 1
    I have a diecast mK1 spitfire @1/24th scale (I think) that I bought years ago.
    the engine cowlings and gun covers are removable, which meant that over the years they have disappeared through my grandchildren's sticky fingers :flushed:
    just wondering if you guys might have some ideas on fixing this.
    You could try to replace them with aluminium sheet, a roll of thin should do the trick and can be obtained from Azon or on evilbay. And is easy to work with.
    Mike
    • stillp
      • 8277
      • Pete
      • Rugby
      What about a foil takeaway food container, or would that be too thin?
      How about a photo Bob.
      • Modler bob
        • May 2022
        • 277
        Yes, probably too thin Peter, needs to be about 1mm thick. thanks anyway.
        When time, I'll search around for Mike's suggestion of a roll or sheet
        I'll get a photo up as soon as I can. :thumb2:
        • AlanG
          • 6296
          Maybe used a piece of a used tin can from baked beans etc? Cut to shape and will hold it once bent.
          • Airborne01
            • Mar 2021
            • 4297
            • Steve
            • Essex
            I have some pewter sheet of about 1mm that may suffice somewhere in the chaos of my cave, if so give me a heads-up so that I can alert International Rescue to come to assist me in locating it!
            • Modler bob
              • May 2022
              • 277
              Great stuff Steve.
              Once again you've come to my rescue
              Let me know the cost/postage etc, please?
              And I'll PM you my address. :thumb2:
              I wish I had room for a cave :smiling2:
              Bob
              • Airborne01
                • Mar 2021
                • 4297
                • Steve
                • Essex
                Originally posted by Modler bob
                Great stuff Steve.
                Bob
                Just send address via PM Bob - no charge, life's too short for swapping pennies!
                • Modler bob
                  • May 2022
                  • 277
                  • Modler bob
                    • May 2022
                    • 277
                    I now have a sheet of Pewter to hopefully fix the Spitfire.
                    All thanks to Steve (Airborne1)
