I've been looking around online for a supplier for very small sized mini receivers. Either 27 /40mhz AM or FM. Fm would be preferable, must be BEC.
I've seen FM receivers about 35 x 20 x 10mm - Is that about as small as they get or is there anything even more miniscule available? Or one with squarer dimensions, being slightly shorter than 35mm long. I have a space about 30 x 25 x 20mm That I'd like to fit the receiver into if possible!
I imagine the largest bulk is actually the casing itself and with a bit of care I could possibly shave another few mm from it and sleeve in heat shrink tube - if I can get one for a reasonable sum!
The receiver fits in the cab of my little loco and at present will mean the drivers legs and lower torso will have to be sawn off so he can fit in the cab! The smaller sized receiver would make a nice little seat for him to perch on too!
:goodidea:
:goodidea:
