A Question of Scale
  • Gern
    • 9273
    #31
    Back to the SWG for a moment. Given that your wire is supposed to fit in a 1" diameter tube, how about if your wire is 0.6" diameter. Then only one will fit in the tube. But only one will fit if it's 0.999" diameter. There's a big difference between those wires, but does SWG say only one will fit so they are the same gauge?
    Duuhhh!
      Just like pure mathematics, of absolutely no use to anybody, but great fun to read.
      If you find mathematics great fun to read, you’re even weirder than me :tongue-out:
      Also, XKCD:
      as always, vested interests and protectionism ruled over common sense.
      And the argument still used by Americans and elderly Brits the world over: “Too difficult, <random mess of units> is much easier (because I know it already)!”
      things that wouldn't mean anything to youngsters - log tables, sine tables, Naperian logarithms, steam tables slide rules, planometers, indicator cards & a lot more esoteric names & kit
      Not just youngsters (well, depending on your definition of youngster, I suppose …). I was in secondary school in the late 80s to early 90s, and we had none of those — instead, we had a Casio ƒx-82 (Or other scientific calculator of your choice, but my school recommended the ƒx-82.)
      I suppose there’s a rule that gauge is the number of wires that will fit tightly in the tube.
      • dave
        • Nov 2012
        • 1844
        • Brussels
        #33
        For shotgun gauges; the gauge refers to the weight of a solid ball of lead that might fit perfectly in the bore of a shotgun, expressed as the inverse of said ball’s weight as a fraction of a pound. For example, the sphere of lead that perfectly fills the bore of a 12 gauge shotgun weighs 1/12 of a pound.
          • 19026
          Advances in knowkledge & especially computers mean most of these are consigned to history -
          Similar things that wouldn't mean anything to youngsters - log tables, sine tables, Naperian logarithms, steam tables slide rules, planometers, indicator cards & a lot more esoteric names & kit
          Used the first four in a couple of jobs, but not for years.
          When a population of bacteria is growing without restraint it is known as being in log growth because when the optical density is plotted against time using log paper you get a straight line.
          Sine tables are very useful in trigonometry and I can’t really see how you can use a calculator to derive them if you don’t know how they work. Go on then Dave…..what was the nmenonic for remembering them?
          Steam tables were an easy way to determine if our fermentation kit was air free when being sterilised. If the temperature and the pressure correlated then there was no air present.
          Napier logs are better known as natural logs. Scientific calculators still have that function on them. I know the fx-82 has, I’ve still got mine somwhere. It was the recommended one for the Open University science course. It’s the Log e button as opposed to the Log 10 o….
          I think 2.303 x Log 10 = Log e, but I could be wrong. Can’t remember what I used them for now…..Logs are easy to explain, by the way. They are just the power to which you raise 10 to get the number in question.
          Oh, and I do enjoy maths. I’d rather solve quadratic equations than solve crosswords if I’m honest……
            All Silly Tom Cats! - positive quadrants!
            A planometer was a mechanical device for measuring the area under a curve - not unlike a precision pantograph. Indicator cards were the plot of pressure vs stroke in a 2-stroke engine - the planometer was used to give the power. You sometime see engine power des.cribed as ihp. or bhp. one being the theoretical power produced by the engine, the other being the useful power.. The indicator cards were taken by another fancy mechanical piece of kit - a Dobbie McInnes Indicator. Very tricky to use,- thankfully superseded by electric strain gauges - which would give continuous readings. The old machines only gave a power reading at one instant & it took about 20 minutes a cylinder to set up & record - not good, when you had 8 cylinders!
              • 19026
              Nice one Dave. I was thinking of SOHCAHTOA, oops! Some Old Hairy Camels Are Hairier Than Others Are…….my maths teacher was a huge Southampton fan, so we had another that started Saints On High, but I cant remember the rest
                • 16027
                A friend of mine showed me the impressive model of Mount Everest that he had just built. I asked if it was to scale, he said, “No, it's just to look at”.
                • boatman
                  • Nov 2018
                  • 14498
                  • christopher
                  • NORFOLK UK
                  #38
                  OH Well the brains have spoken (sigh)
                    You type in the angle and press the [ICODE]SIN[/ICODE] button, or work out the sine from the sides of the triangle and press [ICODE]INV[/ICODE] followed by [ICODE]SIN[/ICODE]. You still need to know how to do it, but you don’t need tables to tell you which angle goes with which sine value.
                    In Dutch: SOSCASTOA — Sinus is Overstaand gedeeld door Schuin, Cosinus is Aanliggend gedeeld door Schuin, Tangens is Overstaand gedeeld door Aanliggend. Which looks to be the equivalent to your SOHCAHTOA, which I had never heard of before just now
                      • 19026
                      Originally posted by Jakko
                      In Dutch: SOSCASTOA — Sinus is Overstaand gedeeld door Schuin, Cosinus is Aanliggend gedeeld door Schuin, Tangens is Overstaand gedeeld door Aanliggend. Which looks to be the equivalent to your SOHCAHTOA, which I had never heard of before just now :smiling3:
                      :thumb2:
                      Basically
                      Sine = Opposite over Hypotenuse,
                      Cosine = Adjacent over Hypotenuse,
                      and Tangent = Opposite over Adjacent.
                        Ah, yes, all those Latin-based terms that Dutch science replaced by ones easier to understand in the 17th century We know the hypothenuse simply as the sloping side of the triangle, for example. Or “physics” as, literally translated, “nature-knowledge”.
                        • Gern
                          • 9273
                          #42
                          Beat me to it! I've actually got that tattoo'd on the inside of my eyelids - along with the general solution for quadratic equations. Came in very handy during exams!
                            • 19026
                            Ah, yes, all those Latin-based terms that Dutch science replaced by ones easier to understand in the 17th century :smiling3: We know the hypothenuse simply as the sloping side of the triangle, for example. Or “physics” as, literally translated, “nature-knowledge”.
                            Yes, but where’s the fun in that LOL…..
                            PS, Pythagoras was a Greek not a Roman LOL…..
                            • Gern
                              • 9273
                              #44
                              Also, XKCD:
                              Not just youngsters (well, depending on your definition of youngster, I suppose …). I was in secondary school in the late 80s to early 90s, and we had none of those — instead, we had a Casio ƒx-82 :smiling3: (Or other scientific calculator of your choice, but my school recommended the ƒx-82.)
                              Calculators! At school! They hadn't been invented when I did my O-levels. I actually saw one of the first calculators to become available in this country when our A-level maths tutor bought one. It was about the size of a hardback airport novel. You know the ones. Those with a greek letter in the title and 950 pages of weapons specifications!
                              (Kids of today can't work out where the batteries are supposed to go so don't bother with them).
                                Oh, does the term come from him? Never knew that … Anyway, I meant most of those foreign words
