A lots been talked about concerning modeling paint brushes before.Never seen anyone mention 1/1 .
Over the years I've tried a lot of brushes , many with synthetic bristles. Some years ago, well over 15 I came across Purdey.
Hand made in the US with the brush makers signature on each one .Not cheap £ 25 pounds for a 1 1/2 in . Like many things the more you pay with in reason the better the quality.
It I've used them at work on finished joinery , at home as well for many projects.
One of the most important things is cleaning ,
Bought one of these " spinners " best thing ever for removing the old paint when cleaning .
Insert brush after the normal cleaning with white spirits when using oil based paints then warm water and detergent . With modern water base paints even better , a quick wash I the detergent mix and then the spin..A final wash in clean water and a final spin leaves the bush as good as new .
Spinner fully extended.
Brush after cleaning .
This brush 10 years old now back in its case ready to use again later .
John .
John .
