Info please
  • Airborne01
    • Mar 2021
    • 4360
    • Steve
    • Essex
    Info please
    I've recently come into possession of these with a promise of more to come in various sizes; they're slightly magnetised and already proving very useful in conjunction with set squares etc. I'm intrigued as to whether I can find a definitive answer as to their original purpose! Are there any 'vintage' engineers out there who can enlighten me? My gratitude will be unbounded!
    They look like part of a set of slip gauges
Name:	slip gauges.jpg
    Obviously they are Imperial
    They were used as standard measurements for cailbrating inspection equipment. They were generally checked against a national standard set of gauges & paper certified as being a 'Standard' , You can see from the Ebay listing Matrix were a maker. They are highly machined, ground & polished precision items. They were very expensive items & in original boxes & paperwork collectable
    • davecov
      • Jul 2014
      • 882
      • Dave
      • Stow, Scottish Borders
      Dave just beat me to it. I was going to say -
      Looks like calibration blocks, similarly to these:
      DaveCov - Founder of The Airfix Tribute Forum 2006
        Steve,
        I don't know about vintage! In an engineering company of any size, there will be a standards room, where these gauges would be kept. Measuring gear in 'goods inward' & machine shops would be calibrated against the standards regularly. Even digital calipers had to be calibrated & certified. The storage rooms were temperature & humidity controlled, so comparisons were done at a stated temperature.
        The standards room also had the library of paper standards - BS, DIN, ISO, SAE, JIS & others, on all subjects from paint specifications to cast iron. As a Design Engineer, anything I cooked up had to comply with the relevant standard. Much easier with computerised storage. The paper standards had to be logged in and out & had to be kept updated - old copies having every single page stamped 'superseded'
        A good steady job for the more methodical worker
          • 16294
          Well Steve you now know what they are. I bought some steel blocks and they have proved useful in many ways. I'm sure you will find loads of uses for yours, to keep things square, as weights etc. You're a lucky guy.
          • Airborne01
            • Mar 2021
            • 4360
            • Steve
            • Essex
            Thanks so much Dave(s) - I feel vindicated in my original thoughts! (And - 'Vintage' surely doesn't apply to a stripling like both of you :rolling: !). And you're absolutely correct Jim - they've proved indispensable already! Thanks Gents!
            • Gern
              • 9306
              I reckon I could find a use for some larger blocks. I wouldn't need them to be precisely machined, just heavy with accurate, square sides. I've seen pictures of blocks with threaded holes which would possibly suit. Does anyone know what they are?
              I've looked on ebay and the sets of blocks have lots of thinner ones which would be of no use to me - plus they're expensive for what I want. What sort of blocks did you get Jim?
              • Andy T
                • Apr 2021
                • 3239
                Sounds like you mean 321or 123 blocks, so called because they are 3 by 2 by 1 inch.
                I bought a bundle of metric ones which are various sizes and can be bolted together if needed. I'm pretty sure Steve Jones bought the same ones after asking about mine.
                • Gern
                  • 9306
                  Them's the bunnies! Sorted. Thanks Andy!
                  • stillp
                    • 8308
                    • Pete
                    • Rugby
                    Cheaper here: https://www.ebay.co.uk/sch/i.html?_f...acat=0&_sop=15
                    • Gern
                      • 9306
                      Originally posted by stillp
                      I didn't get them from the website Andy found, but I did pay more than the ones you found Pete. :sad:
                      I could have used them a few weeks ago on my aircraft hangar build. It's not finished yet - still LOADS of stuff to do - but these blocks will help towards the finish. I'll see how well they work and maybe grab another couple from the site you found.
                        • 16294
                        I can't remember where I bought them, Dave. I bought 3 different sized steel blocks, a steel sheet and some magnets. To be honest the blocks have been used often but my idea to hold things in place with the magnets on the steel sheet didn't work. The smallest block is about 3cm long.
                        • Gern
                          • 9306
                          [ATTACH=CONFIG]n1207412[/ATTACH]
                          Using blocks and magnets to hold things together - and create square corners - seems such a good idea. Pity it didn't work out as planned Jim.
                          I'm hoping the sheer weight of the blocks I have bought - which can be bolted together once I've got hold of some suitable bolts - will do the job.
                            They could have been used in the layout of parts to be checked, you were nearly there with the set squares. We used to use magnetic blocks at British Aerospace in the mock up shop to make sure the parts would not move and other parts checked against them. Bit hard to describe, but in working practice it was part of the job.
                            • Gern
                              • 9306
                              I know it's possible to magnetise steel blocks by wrapping them with wire and running an electrical current through the wire. I don't know what sort - AC or DC - or what strength of current you'd need to get a decent magnetic strength in your blocks (there's bound to be a website that would help you with that - obviously no good if you need tens of thousands of turns of wire and forty eleven zillion amps), but if your blocks were magnetised Jim, you ought to be able to use them for the purpose intended?
