Which Glue,
  • The Smythe Meister
    • Jan 2019
    • 6248
    Which Glue,
    Hi guys,
    I'm putting some tiny bits of etch together for my 111,I glued some bits together with Locktite last night, picked it up just now... And it fell apart...
    Anyone suggest a glue that will actually keep it stuck please?!!
    Any thoughts much appreciated :thumb2:
  • Andy T
    • Apr 2021
    • 3239
    Loctite CA glue? That ought to have done it.
    Solder is obviously the bomb, but CA should work fine for anything non structural. I've started to give the parts a good clean & sanding or scratching with a blade (advice from Scottie if I recall) and it has helped a lot.
      • 19130
      I’ve started using this for small bits of etch…I know it’s for canopies, but the bond is less prone to the bond being affected by finger grease.
        • 16293
        VMS make a CA specifically for pe. It is reckoned to be flexible and less prone to damage. I've used it and it seems to work. I always slightly roughen the pe and the attachment point to help with adhesion.
        • Mark1
          • Apr 2021
          • 4156
          Ive been using this without any issuesClick image for larger version
          • Si Benson
            • 3572
            I use the VMS flexi stuff and it does the job for me. like Jim I also rough the shiny stuff up a bit…..definitely helps!
            • David Lovell
              • 2186
              Originally posted by Mark1
              Ive been using this without any issues[ATTACH=CONFIG]n1217686[/ATTACH]
              Same as but I use the blue bottle one think it gives 10-20 wriggle time and its a glupey one ,can't say I've ever run into any problems. Dave
                I always use Loctite - just make sure the part is free of grease - either wipe with IPA, or pass through a lighter flame
                  • 19130
                  I also find locktite power gel good. A few seconds wriggle room and a slightly flexible bond make it easy to use. Failing that, five minute Devcon is great……
                    • 18302
                    Sounds like a grease problem. As others have said Big structural bit solder them small fiddly bits clean in acetone/thinners/IPA immediately prior to CA, Burnishing helps.
                    A thin PVA type glue is also good for things that are glued flat on a surface. Gorilla grip glue was my go to. I believe they've gone bust though.
