extra magnification
  • Waspie
    • Mar 2023
    • 3488
    extra magnification
    My current 1/72 build has highlighted just how my eyesight has gone down. My reading glasses are fine for - reading! But for that extra something I need more or larger images to help with my new hobby.
    A question for you guys.
    If you use assisted magnification, what make /type do you use?
    There are so many out there an idea from you people that use them would assist me in making my mind up as to what to buy.
    Thanks in advance to anyone who responds.
    Doug
  • PaulTRose
    • Jun 2013
    • 7084
    • Tattooine
    One of those on the head magifying jobbies are good but I also have one of those clamp to the bench illuminated magnifying glass thingys too.........both work for different jobs for me
    Per Ardua
    • Si Benson
      • 3572
      My eyesight is steadily getting worse too, I’ve used a magnifying lamp for years but now I’m also needing that and my reading specs.
        • 16157
        Donegan Optivisor with the DA-5 lens. They are not cheap but have quality, optical glass lenses. They're comfortable to wear and the DA-5 lens is a good compromise between decent magnification and a workable focal length.
        Beware of imitations.
        • Andy T
          • Apr 2021
          • 3239
          I've tried all kinds of magnifiers (apart from the daddy optivisor) but always end up reverting back to +3.5 reading glasses, two pairs for a fiver on Amazon.
          I wear them on a string around my neck so they are easily to hand
          • A_J_Rimmer
            • May 2024
            • 801
            • Arnold
            • North Wales
            I just use a cheap pair of off the shelf reading spec's from Tesco's that I ware over the top of my regular distance glasses - seem to work well (and stops me ruining my £100 reading glasses). I also try to use lots of light.
            Arnold Judas Rimmer BSc SSc
            ''Happiness is a Triple Fried Egg Sandwich with Chilli Sauce and Chutney''
            • Tworrs
              • Jan 2022
              • 1982
              • Garry
              • New Zealand
              Like Jim R says above, the Optiviser is well worth the investment.
              As A_J_Rimmer notes two pairs of specs is also an excellent choice.
              • Waspie
                • Mar 2023
                • 3488
                Thanks for all your replies guys, I have to admit to seeing the Optimiser and was surprised at the cost, end of the day you get what you pay for. However, it's a tad over budget at the moment. That's the trouble with starting out, like teenagers, you want everything NOW!!! But its not practical!
                Seems I'm going to have to compromise somewhere or just wait.
                Andy, I have a problem with your option. I used to wear +2.0 readers but I developed an eye issue as a result. It's to do with perspective, the top of anything I look at is wider than the bottom and it does crazy things with my brain. My current prescription reading glasses are trying to correct the issue. But I appreciate your response buddy but its a road I can't go down.
                  • 19103
                  Cheap ready readers are not of great quality and may not be properly optically corrected, especially at higher magnification. OK if your eyes are otherwise in good condition, but probably not great if you have other eye issues.
                  When I wore contacts I had to wear reading glasses as well (think how varifocals could work as contacts if that sounds weird) so used an optivisor. When I stopped wearing contacts I went back to varifocals. However, my short sightedness is quite marked so working over the top of the glasses gives me a 2.5 magnification, and my optician recommended that I did this instead of wearing anything else.
                    • 19103
                    Your UK store for magnifiers, microscopes & binoculars ✔ Fast UK delivery ✔ Wide range of optical instruments for hobby, school & professional use.
                    Plenty of options here Doug.
                    • Waspie
                      • Mar 2023
                      • 3488
                      Thank you Tim, yup, lots of choice there.
                      • Gern
                        • 9301
                        D'you have problems travelling Arnold, 'cos you don't look anything like your passport photo?! :smiling3:
                        • David Lovell
                          • 2186
                          If your reading glasses are up to scratch and your working at the same distance you read from you should be having no problems ,when you pick up your reading glasses from opticians/ boots /spec savers/tescos etc they sit you down and give you the card to read the smallest print at the top should be pin sharp if it isn't tell em there no good ,when you work with your reading glasses on make sure there not slid half way down your nose there designed to work properly fitted sorry this isn't ment to sound like a telling off but as you know I mostly work in brail scale and have never had a problem using just reading glasses ,I'll put my hand up and admit to trying thoes head band things terrible they make things out of perspective you have to keep tilting your head back to look under them to get a proper look of your work area (or flip em up)but that was just me others seem to think there ok like Si Benson ive work lamps with a magnifier in the top I use occasionally just to check on something but would never work through it sadly Doug now closer to seventy than sixty ive found its no good sometimes if your eyes are tired it seems that is the root cause when it gets hard going now I just retire gracefully from the bench . I think people worry too much if you need to magnify it to see it people will need the same to see what you've done?Dave
                          • boatman
                            • Nov 2018
                            • 14498
                            • christopher
                            • NORFOLK UK
                            WELL i dont have a problem seein anything really wheather its close up or far away till i need binocs lol but on modeling i use head band magnifier with the lens all fitted in an they just fold up an down an twin leds light also fitted to the visor an a over head white daylight light so for me thing are ok an i find this idea saves eye strain but i find it best not to over do it i just do what i set my self to do then have a rest an hope there will be a tomorrow to carry on but i do have glasses but most times dont need them
                            chrisb
                            • Waspie
                              • Mar 2023
                              • 3488
                              Mmmm that’s food for thought.
                              I do use Boots for my glasses, in fact my optician is a fellow modeller. (Figures and Warcraft stuff)
                              Sadly I’m the tother side of seventy and the time spent focusing, especially small scale appears to be my biggest foe.
                              I think this has been highlighted by trying to focus on the tiny parts and the flash and seams being even smaller but noticeable!
                              I certainly don’t want to mess up my eyes, having enough problems with my eyes without adding to them.
                              Thanks Dave, as said, much food for thought:thumb2:
