Anyone know?
  • Bri62
    • Jan 2023
    • 1973
    • Brian
    • Widnes Cheshire
    Anyone know?
    Hi what size the shank is on these drill bits
    [HEADING=2]Tungsten Steel Drill Bit DSPIAE DB-01-20[/HEADING]
    • 19130
    3.175mm according to this place Brian. I think that’s 1/8 inch in old money….
    • Andy T
      • Apr 2021
      • 3239
      I have a set and they are indeed 3.2mm / 1/8"
      They don't fit in some of their own holders that are 3.0mm :tears-of-joy:so check that as well.
      To be honest I don't rate them, I've broken half of mine after only a couple of uses, whereas the modelcraft / microbox set I have is still going strong after a few years. Never broken one, but lost several lol
      • Bri62
        • Jan 2023
        • 1973
        • Brian
        • Widnes Cheshire
        Thanks guys looking for some 2.3mm ones the drill I have won't take 1/8"
          • 19130
          To my mind, a 2mm HSS drill should be tough enough for any modelling application. Why do you need the shank on it?
          • Bri62
            • Jan 2023
            • 1973
            • Brian
            • Widnes Cheshire
            I don't need it but the 2.3mm shank fits the collet in my tamiya electric drill nice and having them all the same is good no matter if it's a 0.4 or 2.3 drill
              • 19130
              Ah, get it now, you have a collet chuck, not a four jaw. Would another approach be to look for a different collet set for the chuck so standard drills would fit?
              • Bri62
                • Jan 2023
                • 1973
                • Brian
                • Widnes Cheshire
                The actual hole in the screw on collet cover is only small so that's the limiting factor.
                found these
                  • 19130
                  Not making it easy for you are they . Looks like they‘ll do the job though :thumb2:
                  • Bri62
                    • Jan 2023
                    • 1973
                    • Brian
                    • Widnes Cheshire
                    Yeah Tim still got a shed load of holes to open up and the clear plastic is very brittle and blunts them pretty fast
                      • 19130
                      You can resharpen HSS quite easily. Used to be able to buy a device to sharpen mini drills, but I can’t remember what it was called……
                      • langy71
                        • 2055
                        • Chris
                        • Nottingham
                        Drill sharpening tool ?.... (sorry mate, couldn't resist...lol)
                          Micrbox every time, some of the other knockoff offerings are s............ and made of the same stuff. Like you I can go through the cheapies like water...
                            • 19130
                            It’s called a wishbone drill sharpener Brian, designed for micro drills.
                            Very droll Chris…….
                              • 19130
                              Must admit I just buy replacements as job lots ten at a time and use the micro box to hold them. Don’t break many, even the very small ones , but I don’t use them powered. I just use them manually powered in a hand Chuck. I think powered mini drills are designed to break drills and sell more drills :upside: In sheet stock I sometimes just drill a pilot hole and open it to size using a five sided tapered broach.
