More vegetation for 1/35 scale
    With no interest in the build recently with some much going on here , some will know and understand I've spent a lot of time in the garden, Christine's and mines favorite place out side of the house.
    A short time ago I looked at some shop bought veg, and thought I could match it. Took a selection of Phlox leaves and put them in some glycerine and left . This morning finding some lovely long stemmed moss I removed the Phlox and put it in. Will only need a max of 2 weeks.
    This what I've put out to dry.
    Then one on the right is of course a fern, decided to try this as the lover segments may be usefull.
    Once fully dry and boxed they will be painted as required.
    JR
    • 16294
    Looks as if that's been successful. I'm sure they'll find a place in one of your eyecatching dios.
      I do hope so Jim, many thanks .
      • Si Benson
        • 3572
        Nothing more satisfying than making your own bits and pieces like this :thumb2:
        • Richard48
          • 2244
          • Richard
          • Clacton on Sea
          Great idea John.Very satisfying as Si says.
          Rich
            Spot on Si.
            Hope your all well .
            Rich
            Thanks Rich
            • rtfoe
              • 9227
              • Richard
              • Shah Alam, Malaysia
              They look great John. Definitely a satisfying detour and a good supplement to your future dios. Put a figure next to one of the plants so I can figure out what they'd be relevant for...I'm guessing tall undergrowth along footpaths.
              Wabble
              • boatman
                • Nov 2018
                • 14591
                • christopher
                • NORFOLK UK
                WELL JR what a crackin idea very well done my freind an save some dosh as well
                ATB TO YOU SIR
                chrisb an jen
                  Wobble,
                  I do worry about you sometimes, you sit in your lounge chair stroking your Albino cat Terrorist. When passing at night I see all sorts of flashing lights and hear weird noises - can you tell Christine to turn over as she is frighteng the Rottwieler.... But getting back to you, all of this experimenting has got to stop, just the other night I met a drunk Palm tree leaning against a lamp post wearing a bowler hat and asking for help to get back through the letterbox....
                  • boatman
                    • Nov 2018
                    • 14591
                    • christopher
                    • NORFOLK UK
                    WELL ISITME thats gonna take some workin out how many pints have you had sir LOL
                    Chrisb
                      Wabble
                      Wabble, you would be able to cut them to size, as per the leaf joint. They would be a bit tall for normal vegetation in Europe if left the full hight.
                      ATB TO YOU SIR
                      chrisb an jen
                      Thank you Chris.
                      Wobble,
                      :smiling2::smiling2::smiling2::smiling2::smiling2: :smiling2::smiling2:
                      Chrisb
                      Not drink Chris, its the effect you get from inhalation of TET . Normally Wibble is ok, but at the coming of the end of summer he does have the odd turn. Regardless of this I still consider him to a good friend.
                      • vizenz
                        • Apr 2024
                        • 426
                        Hey John, very interesting. Can you explain the process, how and why you do it? Do the plants then become durable or like plastic or how does it work?
                        Best regards,
                        Andreas
                        • Steve Ski
                          • Jul 2024
                          • 222
                          Excellent. I've done this before myself, with a bit of a mess, but it's worth the effort for specific veggies required, no doubt. The key here is finding the stuff you'll need and it is not always an easy task. These all look great, John.
                          Give Blood, Play Rugby, cause everyone knows football is for whimps!
                            Best regards,
                            Andreas
                            certainly, Andreas, the idea is to preserve the plants , sea foam is perhaps the better known of all . Once dry they maintain their shape and last indefinitely. I've found some plants species like the sea foam go firm
                            , whilst others will be more pliable .
                            The method I use is as follows
                            Mix glycerine with water , 3 to 1. I use warm water for the initial mix, however I keep the mix now in some jars for small projects and don't bother with any warm water , mainly as it's mixed.
                            There are differing mixes given on the tube and many different methods.
                            Some people spray the sea foam over a bowl, then hang up to dry, allowing the plants to drip any mix onto paper placed below.Another method is to hang the plants from the top , fixed weights to the bottom of the steam and keep the plant into a straight.There is a video on UTube showing this , a search is most definite , I found this just now
                            might be of some help .
                            I prefer to completely immerse what ever I'm attempting, cover and leave for at least a week or two . Remove and wash off with fresh water .By now the plants will have absorbed enough mix .
                            Leave to dry, as it the case of the Phlox , but when I attempted pine branches using asparagus fern I weighed them down , like a press, placing the plant parts between paper and the placed a load of book on top .
                            Moss is very easy as it's small, just the right size for small plants on a dio .
                            Hope this helps .
                            Jr
                              Thanks Steven , yes It can get messy, but the results are well worth the effort.
