Photoetch adhesive
    Photoetch adhesive
    Hi all
    What are your thoughts on the best ahesive to attach photoetch parts.
    Thank you
    Originally posted by \
    Hi allWhat are your thoughts on the best ahesive to attach photoetch parts.
    Thank you
    Hello again Dave, I use Locktite precision gel superglue for all my photo etch parts as well as for any resin bits and pieces. It is good as it is controllable and less likely to stick yourself to any thing. It is expensive for what it is but it has a lot of uses, as I like to use it on fiddly and awkward bits on my models also.
      Thank you for your reply i will try some of that.
        pe adhesives
        :washing:
        Thank you
        - hi dave , i use thick/thin cyno , white glue and even clear varnish ( for the really tiny stuff , it gives you a chance to adjust it and is quite strong enough ) not much 'poxy though . i find its too lumpy and stringy to work with .
