my doirama
    my doirama
    my diorama (ambush at kursk)
    here is the link to my diorama i made. its my first proper one
    That looks pretty good 50! I would mention just a couple of things though-Kursk was fought in high summer so the grass & foliage would have been less green that that, more yellow & faded. Also the strip of grass where the Russians are is a bit too straight & even. Have a think of this-change it so it's the Germans being ambushed, put them at the highest point (away from the path) as if they're firing over a ridge with the Ivans creeping up on them from the path. That would look good! I'm not trying to pick holes in your work, mate coz it's a good one, just offering some ideas to make it even better. Patrick
      your attually right about the grass it is a bit too straight but i cut it out and stuck it on so it would be a bit hard (well hard for me!) to make it more naturall then straight!
        That's easily sorted next time mate, just cut one side with scissors till it's kinda ragged & with white glue, add some dirt mix over the edge-it'll look nice and natural then. Keep up the good work! Patrick ps one last thing-your MG barrels look very silver? try painting them black & then very lightly dry brushing with silver, you'll find it makes them look more realistic.
          not too shabby 50.cal keep up the good work.
          scott
            the reason there silver is because when i painted them i had no black and the local model shop was closed so i couldnt buy any black paint. i could of just bought black the next day but i really wanted to make this kit so i painted them silver. i might attualy go paint them black now!
            • Gern
              • 9306
              Hi 50.cal.
              That's really good for your first attempt - I like it. You might want to look at the moulding seams on a couple of the figures though.
              Lots of folk reckon you should file them off with a variety of shaped files. I used to do that and you get some very good results with care but it is time-consuming. I just scrape mine with the edge of my modelling knife blade where there is material or cloth on the real figure, this leaves a slightly rough surface which doesn't matter as it is supposed to represent cloth; and leave the files for areas which have to be smoother or with fiddly shapes and contours to line up. I find this method much quicker and it is accurate enough for my simple needs.
              Looking forward to your next one,
              Gern
