I'm about to start work on an M1127 Stryker (RV) in 1/35th, the plans seem pretty straight forward & the parts are highly detailed, to add more detail to the finished model I want to add 'weld' beads, what is the simplest & easiest way to do this? someone suggested excess glue & a cocktail stick to make it look like a weld joint but I've been un-successful so far.
welding joints.....
GuestTags: None -
Hi Ben, the most common way to add weld beads is to use either stretched sprue or thin plastic rod, stick it where needed, then add liquid cement to soften it & use a knife to add the texture. I find this complicated & tend to get the glue where it shouldn't go! I've found it easier to use Miliput by rolling it into very thin strings, apply it & add the texture with a small jewellers screwdriver tip. The advantages are that Miliput sticks well without the chance of liquid cement going everywhere, it moulds well to the surface & as long as you keep the screwdriver tip wet, it shapes into a realistic bead very well. It's all about practice & experimenting to find what suits you the best. Patrick -
Beat me to it Patrick, i was going to say about the stretched sprue but never tried the Miliput idea though. Will give it a go later, cheers mate.
JohnComment
Guest -
Thanks for the great advice guys! Can't believe I never thought of Milliput before, it's the only thing I haven't tried & I have loads in my box, will keep you posted on how my 1st attempt goes
regards
BenComment
