Hey peeps...any ideas for a good plaster in the UK to use for landscaping on to a base at all. I have no idea if a normal plaster your can get from a DIY store would do or a specific modelling/craft plaster that is sold for that use. Any recommendations?
diorama landscaping plasters
Plaster
Standard wall plaster is relatively coarse stuff but may do for the scale you are working.
For a very fine white plaster you need plaster of paris available from model and art shops.
You can also get plaster of paris bandages if you know someone who works in a hospital with an A&E department, which you cut to length, wet and smooth over your base shapes.
I've used this for a non-modelling job and it worked well.
Peter -
For casting I use a variety of plasters from here www.maragon.co.uk/arts-and-crafts.html#Init and sculptamold from here www.ngtrains.com/Pages/Scenic/sculptamold.htm .
Joolz.Comment
For landscaping, contours and muddy ruts I always use grey floor tile adhesive. It is in a powder form and mixed with water it produces a consistancy of cement. It doesn't crack and can be moulded into fairly intricate shapes, bricks, pavings, walls and the like. One of my dioramas even has a snowman made of the stuff!
It is very cheap, costing around £6.00 for a 10kg bag! ( you can get 5kg too)
RonComment
