i have accidently got paint thinner on a clear piece of plastic and now it have created a fog/mist like effect. does any one know how i can solve this?
					help required
	 GuestTags: None GuestTags: None
	 Guest Guest
 First of all welcome to the forum.
 I don't have the definitive answer to your problem but in the past I have found that you can remove scratches from clear plastic by polishing with ordinary toothpaste.
	 Guest Guest
 welcome to the forum Daniel , can you tell us what model your doing - make and scale , also what part is messed up , with this info you might get someone who has a spare or has an idea how you can overcome this problem
 RichyComment
	 Guest Guest
 A spare would be the ideal but it may be down to a light sanding with very fine sanding/polishing sticks to bring it back. If no one has a spare you could always try the kit manufacturer, most hold spares and some are really good at replacing a part with little or no questions asked.Comment
