I've been absent from model building due to my work schedule. I graduated high school, so that frees up about 6 hours. We got the garage all cleaned, and there is now space and a work bench, so I've started setting up a work area. I'm pretty excited about it because now I won't have the hassle of putting everything away, like the air brush compressor.
					Just checking in
	 GuestTags: None GuestTags: None
	 Guest Guest
 Good to see you back Bojo. Sounds like you will be having some fun when you have your workbench set up. It certainly helps when you can leave your gear set up. I have only just reached the stage of having my own 'Cave' and it is a blessing I can tell you. Look forward to seeing more when you get going.
