Tamiya extra thin?
    Tamiya extra thin?
    Tamiya extra thin glue.
    If anyone knows where i can order some PLEASE let me know...its like gold dust this stuff, regards Martin :-)
    I think its banned in the UK, but I have always found GSI Gunze Sango Mr Cement to be the mutts nutts.
      Saw some Mr cement yesterday, nearly bought it but decided not to as i did not know how good it was, bugger !!!!!
      You can get Tamiya extra thin in the UK, its just very difficult to get a hold of, Mr Models normally sells it but is outta stock at the mo, cheers though dude. :-)
      • John
        • Mar 2004
        • 4698
        • John
        • Halifax
        I use it all the time it's really good stuff, at the moment ebay is your best bet, mine cost me about £5.50 took less than a week from Hong Kong, it's supposed to be available in the UK soon but not sure when
        www.scalemodelshop.co.uk
          There could be a turn around with Tamiya chemicals at the moment, in a model shop in York over the weekend and they had mountains of Tamiya paint thinners (250 ml bottles), I asked the guy about the thinners and he said Tamiya have now re labeled the bottle to pass EU laws, Maybe this might be why its difficult to get the cement.
          • stona
            • Jul 2008
            • 9889
            I heard that it was a labelling issue a while ago,hopefully Ray's suspicions will be confirmed making it more readily available.
            I bought a couple of bottles from Hiro Boy and have nearly finished one. I can confirm a high rate of evaporation if you don't put the top on properly....doh.
            It turns up from time to time,I know Vince at Modelsforsale had some in a while ago and I seem to remember someone else (maybe Graham (Relish models)) had some. Neither have any at the moment.
            Keep your eyes peeled or,as John suggests,order from abroad.
              Cheers guys...what is it with Tamiya an their labelling issues, in this day and age you would think they would get stuff like this sorted...was this not the issue with their new spray paint range, they must be loosing out big time in the uk market by being so clumsy in not getting a simple issue like labelling right!!!
              John i will give ebay a go thanks for that info...i could do a black market trade in the stuff lol :-)
              • AlanG
                • 6296
                Sorry to ask such a basic question but... what is this extra thin stuff?
                • stona
                  • Jul 2008
                  • 9889
                  It's just a very thin cement. It has the consistency of water and will work its way along joins by capillary action. It is pretty hot so you need to be careful where you put it! I think it is mainly MEK,a well known solvent and componant of a lot of plastic cements. I love the stuff and use it on everything that I don't superglue. It cures quickly too,you can usually be sure a join is made in about 10 mins though obviously the longer you leave it the better.
                  • AlanG
                    • 6296
                    Cheers Steve. MEK you say? I have three tins of that sitting in my shed lol.
                    • stona
                      • Jul 2008
                      • 9889
                      If that's the same stuff,methyl ethyl ketone a.k.a. butanone,then it will work exactly like Tamiya extra thin and be a lot cheaper. have you tried it?
                      • AlanG
                        • 6296
                        Never tried it on plastics before. We used to use it alot in the RAF for cleaning/de-greasing. Hence why i have three tins of it. I also had a bad experience with it and cannot stand the smell of it now
                        • yak face
                          • Jun 2009
                          • 14236
                          • Tony
                          HI martin, if you get fed up of waiting for the tamiya cement ,you could always try good old cellulose thinners. I have used this stuff for years to glue my models and can vouch for its effectiveness. Its used in exactly the same way as the extra thin cement but its alot cheaper- I got 5litres from my local car spares shop for about £7 (admittedly it was AGES ago ,i think its about £10 now) Itll last forever , I fill an old marmite jar and use it from there with a nylon bristled brush , that way the big tin can be kept sealed out of harms way.If you want to experiment you could buy a smaller tin ,say 200 ml from most hardware shops. Hope this is of some use , cheers tony
                            Decant a little into a spare bottle, (not plastic) , and get a fine paintbrush and give it a bash, basically hold your bits together, (the plastic kit bits, ooeer missis), and holding the seams JUST apart run bead on the brush the length of the join
                            Let us know how it works and if it's good can you send me a wee bottle with the Kits please :grinball2:
                            I know, i'm a cheeky bugger, my parents always used to say it gets you things though, (usually a clip round the ear from my dad when i used it with him)
                            On a side note, is it a good degreaser? Curious as i've fallen out with Gunk, it's messy, smelly gets everywhere and just doesn't clean up neatly enough for me and i've got a bike i'm needing to attack now it's part stripped and if so is it easy to get hold of in civvy street?
                            Thanks
                            Oh, on the cement side of things, I use Humbrol thin stuff and have done for years, (when I got sick of tubes splitting and setting etc), it's in a glass jar with a fairly coarse brush but I cut down the bottle one to just a few strands and use a paintbrush for hard to reach areas, (where possible i try to cement things internally to make the outside easier to clean for paint), I do use tube stuff also it just depends on the bit i'm gluing.
                            I suspect the Tamiya stuffs stronger but not havong yet tried it I can't say.
                              I use Humbrol Liquid. Easy to get hold of, last for ages but as Mike says, the brush is far too big. I did exactly the same thing Mike, cut it down until it woks the way you want it.
