How easy is maskol to cut when it's cured? I was thinking of pouring some out onto a bit of smooth glass/tile and letting it set. Then i was going to cut a shape into it and try and use as a template. Would it work?
					Maskol question
	 Guest Guest
 I used it years ago, painted loads of layers waiting for one to dry before the next, on a wheel of a kit which I then peeled off and I had a mould. Although it smells awful, basically it is rubber and will flex OK so I would imagine it would cut with scissors or a sharp blade. Not sure if it will start t decay over time though, never tested it. I cast a few spare wheels with resin and got good enough results to add to the back of a lorry as spares.
	 Guest GuestComment
