I've used this product twice now and on each occassion it has, to use the vernacular, gunked my airbrush up big style. I have been told it can be airbrushed neat or thinned to 5-10% with water The first occassion I used it, I did it neat and nothing came out and it needed to be spring cleaned to get anything flowing again. Today having thinned it, I actually got some out but at a very low pressure. I was spraying at about 20 psi and have a 0.3 needle. I cleaned it out afterwards with water, (two or three flushes) and a couple of AB cleaner to be sure. Later this evening I used the AB again and found the flow was zero to minimal. I thought the paint I was using might be too thick but when I wiped the nozzle I noticed a what looked to be a thin piece of paper or cotton. It turned out to be a small piece of leftover varnish. I normally use the Xtracrylics matt varnish with 10% water and it flows fine with good results and normal cleaning. So what's up with the gloss? Is it me and I'm using it wrongly or has anyone else had problems with it. Its now languising in a dark cupboard till this is resolved!
Keith
					Keith
