Hey all. I'm currently in the process of building my own spray booth. Im going to be powering the spray booth with a Bilge Blower Motor. Does anyone know how I can supply power to this bilge blower motor ? I'm totally clueless on how I'm going to get power to this motor. Any help would be greatly appreciated. Here is a photo of the Bilge Blower Motor I'm going to be using and some facts and info about it.
Housing is molded tough corrosion-proof ABS plastic. Rugged built-in mounting brackets for easy installation. Molded tabs on all hose flanges provide positive hose connections.
Ignition protected
Spark proof
4" (10.16cm) Intake
4" (10.16cm) Exhaust with remote bracket
5-3/4" (14.61cm) Length
4-3/4" (12.07cm) Mounted height
CFM 240 Air movement.
Ignition protected 12V DC, 4.5 Amps
Use 5 Amp fuse.
Blower meets or exceeds these standards:
ABYCH H-2
NMMA Certified
USCG 33 CFR Sections 183.410 and 183.425
ISO 9097
UL Listed
UL 1128 Standard Marine blowers.
50-41841
[ATTACH]54161.IPB[/ATTACH]
Ignition protected
Spark proof
4" (10.16cm) Intake
Use 5 Amp fuse.
ABYCH H-2
NMMA Certified
ISO 9097
UL Listed
50-41841
