Decals
    Decals
    Hello
    Having finally accessed the contents of my Decal Fix I have started applying the decals by adding Decal fix before and after.
    Am I ok then to varnish on top of the whole surface, with, in this case, matt varnish? Is there any special technique please?
    And I need to trim one of the tail decals as it's hanging slightly over the edge. Any tips here would be appreciated too please.
    Many thanks
    Aidan
  • HAWKERHUNTER
    • Feb 2012
    • 2071
    • Steve
    • Halifax, West Yorks.
    Its not a problem to varnish over a decal once it is fixed and dry. Use light coats of varnish. As regards trimming the decal, not something I have had to do after fixing. A picture of the problem may be helpful. You will only get one shot at this and the advice needs to be right.
      Aidan. I have also had this problem with over size decals.
      Now cut the decal very close to size & try dry then trim before fixing. But have used in the case of a problem as you describe a Morton knife cut then finger nail scratch. On the bit you want to remove !!! All before varnishing obviously.
        Photos attached
        I must not have been clear in my post. I put the decal on and then found it was too big. I never imagined that decals can be too big - still - it's a continous learing curve.
        [ATTACH]51630.vB[/ATTACH][ATTACH]51631.vB[/ATTACH]
        These poor quality images will hopefully show the problem. Am I ok to trim the decal with a sharp scalpel blade or this there a better way?
        Thanks
        Aidan
        [ATTACH]54215.IPB[/ATTACH]
        [ATTACH]54216.IPB[/ATTACH]
          Actually, looking at that pic - it's not showing much. Lighting? But there is a considerable amount of overhang on the decal.
          • stona
            • Jul 2008
            • 9889
            I trim decals like that when they are completely dried. I use a new and therefore very sharp scalpel blade.
