I've just spent a really frustrating evening fixing an aerial wire on my Airfix Hurricane.I normally use nylon fishing line for this job.Ive tried stretched sprue which I can stretch ok.But I've only got to look at it and it breaks.Getting the fishing line to stick to plastic and remain under tension is a real pain. I bought some super glue at Telford that claims to bond instantly .
But it wouldn't bond and I ended up using my usual Loctite superglue which eventually did the job.I always remove the paint from the plastic,so that's not the problem.I also tried to fix part of the undercarriage with this Rocket glue.That was a plastic to plastic join and it wouldn't do it.A waste of £4 I reckon.My next build has a lot of resin parts.So I will give it another chance before I chuck it in the bin.
