Had a bit of a scare yesterday; was browsing the net for info on my F-14 Tomcat, when a very official looking screen suddenly appeared warning me that I had violated copyright material, and Interpol was tracking me down using my IP address.  The screen also advised that my computer was blocked unless I paid a £100 fine.  I shut down the computer, and on re-booting had the same message appear.   I shut down the computer again.  I should add I am religious about secutity, I have the full McAfee BT NetProtect Plus; I keep my Windows up to date, and run full scans with McAfee and Windows Defender frequently.
Suspecting a scam I went on my laptop and browsed for this scam and sure enough there was plenty of websites addressing this issue and suggesting advice. However I chose my own solution, I re-booted in Safe Mode and ran a full McAfee scan, which came up with two visuses. Upon re-booting the same screen came up again, so I re-booted in safe mode again, and ran the Windows Restore software to a restore point 48 hrs prior. This solved the problem, computer is running normal now.
A lot of the websites eventually want you to download expensive software to fix the issue, but the above solution worked for me on Windows 7/ Explorer 9.
Cheers Derek
Cheers Derek
