Wonwings diary-A selection of flying machines for today.
Jean Battens record breaking Percival Gull G-ADPR, when owned by the Shuttleworth Trust,at Old Warden and seen being flown here at one of those lovely evening flying displays when the air is so still,the aircraft is now on static displayat the Jean Batten Memorial Auckland International airport,New Zealand and preserved in a special building.
This is a flying replica of the German Me.262,the aircraft is one of a small batch of four,which were built exactly to the specification of the original aircraft using an original machine captured during WW2, and stored with the U.S.Air Force,the only concession is its modern jet engines,the life of the original motors could be measured in hours before they literally blew up due to the right metals not being available back then,the aircraft above was flown briefly during November 2002 making a short hop down the runway,ballast had to be added to the nose to compensate for the lack of armanent,this exciting project should make a special appearance at the Berlin airshow this year.
Low level beat up by a preserved B-17,there are still a few dedicated operators of the Flying Fortress in the U.S.A and we are fortunate to have our own 'Sally B' here at Duxford UK.
B-17 converted as a flying water bomber by the U.S Forest service,several types of bomber were converted for this task and called 'Borate Bombers' one was even fitted with turboprop engines.
You can almost hear all of those engines in the B-36 bomber,six pusher piston engines with four tip mounted jet engines the B-36 was unique and looked most impressive in flight.
Just look at this classic shot of one coming into land.
Howard Hughes Spruce Goose now in a museum following some years outside,the aircraft made a single short hop but Hughes immediately realised the limitations of such a large machine with such marginal performance and the Spruce Goose was never flown again.
When placed into the museum,a special plastic coating was applied all over the airframe to help preserve the all wooden structure.
Hughes was constantly at loggerheads with the U.S.Navy especially over the supplies of good quality plywood,the Navy department tried to fob him off with inferior timber keeping the best for the war effort,a thorn in the side as he had little time for officialdom or bureaucrats in his constant battle for his many plans.
ave Peace.
