Micro Radio sets.
(See model HTR48725)
Here is a good one,or a cheaper way perhaps would be to buy a standard Transmitter,a Jeti mini Receiver with BEC ( Battery elimination circuitry) and three/four micro servos,have a word with Midland Helicopters,Hinckley for a good deal on the Jeti and servos,you will need a lithium 2 cell pack and a compatible speed controller ( lithium batteries should not be run flat and these controllers cut off the motor when a certain voltage is detected ) so to re-cap you will need-
Jeti BEC Receiver ( RX)
A standard 3 to 4 function Transmitter
3 to 4 Micro servos
P-Extra-Air 14 Electronic Speed Controller (ESC)
Lithium 2 cell pack 7.4 800 mamp
Dedicated Charger for the battery
State these when you ask for a quote,dont forget that they can be swopped from model to model,I use a module board which screws into different models,all you need to do then is connect up the linkages to the controls.
Dont worry the insructions are self explanatory,and above all you will get unlimited support here when screwing in the radio etc.
3 to 4 Micro servos
