its a old figure before i had the airbrush so i would have painted it with tamiya xf15 i go with a few thinned down coats so you keep the detail..then a wash of any brown oils leave and then highlights..there are people on here who could help you better but i hope this helps
Thanks
I have posted a question about this but I din't really undertsand the replies I received so I'm still wondering.
I've got X15 but it appears flat when it dries. I'll try a wash of something or other.
have you got the amazing never spoke about Johnson Klear give it a couple of thin layers with xf15 then put the klear on to give the face a shine so its not so flat..then go in with the oils
I heard that sprinkling your static grass on the glue then using a balloon that has been rubbed on a head of hair makes the static grass stand on end...a balloon is pretty cheap right =p
There is also ways to make your own static wand, a google search should provide.
