1:48 Spit technicians
    Hello
    I'm coming to the end of my Revell 1:48 spit MK16 which has a fully exposed engine and open access points to the guns in the wings.
    I haven't yet stuffed it up so am planning, if the build and paint quality continues, to make a dio. With the engine fully exposed etc I'd like to put some technicians all over the plane doing maintenance, perhaps an air compressor and some boxes of ammo to put on top of the wings.
    Can anyone very kindly recommend some nice accessory kits please?
    Thanks
    Aidan
    (It's 40 days since Christmas)
    • 18302
    ICM do a crew figure set, The same set is also availiable in a revell box. Eduard do a set which they are loading the ammo .
      As Ian says Revell do a kit for 1/72 & 1/48.
      They have arms legs & heads (you will be pleased to know) which you stick on at whatever angle you want. Best not to have the head on the same side as the back.
      If you look at my gallery they are in some of those pictures.
      Also have bomb carts air cylinder carts a trestle & step ladders. A nice kit.
        I have the Eduard set - very nice quality, posable arms, heads, etc and has a couple of guys for loading the guns on the wings
        Cheers, Neil
