Trumpeter Razor Saw
  • Vaughan
    • Apr 2011
    • 3199
    Trumpeter Razor Saw
    Hi I know John sells Trumpeter and Tamiya saws in his shop but has anyone used one and which would they recommend? I need to cut the wing tip landing lights off the P47 I'm building and replace them with clear plastic parts.
  • stona
    • Jul 2008
    • 9889
    I use a Tamiya razor saw for general stuff like removing resin casting blocks and it works very well.
    For very fine stuff I use one of Radu Briznan's fine saws from RB Productions. You need to buy his "handle" to hold the very fine blade as well. It's a bit of a do screwing the thing together but you can make very fine cuts.
      Vaughan. I have the Trumpeter saw. A couple of blades. Would not say it was a very fine toothed saw but works well. Blades are very simple to change just a sprung slide. One of the blades is a very neat thing easy to get into difficult areas. The other a more robust blade.
      Just to add that with the Trumpeter you will have to undercut then finish to fine points with a file or a blade sander.
      • Vaughan
        • Apr 2011
        • 3199
        Thanks Guys so would they be fine enough to cut the landing lights or do I need a finer saw? Steve what did you use to cut your landing light on your P47.
        • stona
          • Jul 2008
          • 9889
          That was probably one of the RB Productions saws.
            Vaughan. To date I have only used the saw for cutting strips of plastic with out any great accuracy.
            But just had a couple of goes at cutting into an old wing & very surprised the cut was perfect. Provided you are accurate & careful the cut is clean & not ragged as I had suspected.
            • Vaughan
              • Apr 2011
              • 3199
              Thanks for the info Laurie. I will admit that I ordered the Trumpeter saw from evilbay(sorry John) it did work out a bit cheaper than The Shop but might still buy another finer saw, will see what the Trumpeter one's like first.
                Vaughan,
                Try these
                ONE
                TWO
                I have both and they work very well
                Hope it Helps
                Regards
                David
                • Vaughan
                  • Apr 2011
                  • 3199
                  Thanks for the info David they look very good. Will have to see what the trumpeter saw looks like when it arrives.
