Klear removal?
    Klear removal?
    Hey guys, I have noticed a small run in my Klear coat, is there any way of removing it other than sanding the area down? :thinking:
    TIA
    Soak it in klear, let it sit a few minutes, wipe clean, repaint, it dissolves in itself. Alternatively a 6% ammonia solution or window cleaner with ammonia will dissolve it.
      Depending on size of run and location, I would try sanding just the run with a suitable grade wet and dry and a touch up with Klear coat.
        Okay, thanks guys. It's a small run but looks considerable on 1/72 scale. Fingers crossed
          • 18301
          If its the Klear as in floor polish, as M1ks said it will dissolve its self, so just give it a bath in some more and once soft wash it off.
          If its a clear varnish, wet and dry will be the way to go.
            It's Klear floor polish Ian. It's only on one small area, so I'll put just a drop on the area and leave it for what, a few mins?
            If that fails it's wet and dry.
            • stona
              • Jul 2008
              • 9889
              Happens to me all the time!
              Cotton bud moistened with a dilute ammonia solution,as per m1ks,followed by a fresh coat works for me.
                Originally posted by \
                Happens to me all the time!Cotton bud moistened with a dilute ammonia solution,as per m1ks,followed by a fresh coat works for me.
                Cheers, Steve
