... possibly for my JU88, it might be the first ever occupant.
This has been a most frustrating build, it has fought me all the way. The terrible Revell engineering and dreadful instructions combined to rob me of all enthusiasm for this model.
But I have persisted and this morning removed the masking after finishing the splinter camo.
For the first time ever two patches of paint came away leaving clean plastic showing. Not large areas, no more than a square inch in all but very annoying. The paint job looked great until then.
After that, while removing the masking from the undercarraige, one of the legs broke away with the masking.I had problems with that poorly engineered area of the build anyway. On both undercarriages the wheel axles have broken off completely anyway, mind you these are inadequate and would need something done with them.
OK none of this is terminal. I can repair it all but I just have no enthusiasm left for it. Even then I suspect that when I remove the masking from the front transparency some white filler will show through and if so the whole model will end up in the dustbin anyway.
That is it - I am taking a break from it for a couple of days and will decide Monday evening what to do. I have never given up on a model before but sometimes enough is enough.
