I used Evostick contact adhesive for the joins wheelwell-cover-to-metal; wheel-to-metal, metal-to-model, both port and starboard, and for the rear wheel. It has formed a strong bond.
					Glue for Diecast Parts?
	 Guest Guest
	 Guest Guest
 One glue which would have done the trick, I for got to mention, is Gator glue also marketed under the name Gorilla Glue.
 Very tough glue which slightly expands as it cures. Can be moved for a while rather like Evostick the way it cures. Best to roughen the plastic to give bite. Can be, whilst still wet, wiped away with water. If you use apply frugally as it does expand a fraction & will using to much dribble foam out of the joint.
 LaurieComment
