My next scale project, an SE5a, is at the early design stage. One thing I’m considering is to use scale closed loop control runs for the ailerons and elevators but for this I need some small pulleys. They need to be near enough the correct dimensions as they will be visible through the transparent inspection covers. See Photo.
The size I need is approx. 9mm diameter by 3mm thick to take 0.8mm control cable. Does anyone here know where I might get some? I thought this sort of thing might be used for model boats but I’ve “Googled” the Internet without much success.
Any suggestions will be gratefully received.
[ATTACH]13424.IPB[/ATTACH]
