E shape BoB Dispersal pen
    I am building an E shape BoB Dispersal pen. How big should it be? I have already started and will be posting photos soon cheers
  • flyjoe180
    • Jan 2012
    • 13100
    • Joe
    • Earth
    According to this: http://en.wikipedia.org/wiki/Blast_pen
    either 150 feet (46 m) or 190 feet (58 m) wide and 80 feet (24 m) front-to-back.
    Although the pens were open to the sky the projecting sidewalls preserved the aircraft from lateral damage, with 12-inch (300 mm) thick, 9 feet (2.7 m) high concrete centres, and banked-up earth on either side, forming a roughly triangular section 18 feet (5.5 m) wide at their base.
      Thanks. I am starting on their construction. The Actual base has taken shape as I carved out a base/outline out of balsa. I am going to mould the stuff on top of that. There is going to be an inner bunker as used in the E shape pens
        Change of plans. I am making an Acrylic mould, designed out of Prodesktop 8. I will then vac-form molten plastic out of the mould.
        • flyjoe180
          • Jan 2012
          • 13100
          • Joe
          • Earth
          Look forward to seeing it John.
          • stona
            • Jul 2008
            • 9889
            Is this any good to you?
            Some good stuff here, just accept the condition, it's free
            http://archaeologydataservice.ac.uk/archives/archiveDownload?t=arch-882-1/dissemination/pdf/acarchae2-127600_1.pdf&Cheers
            If you are ever near Bristol airport and have a tape measure handy......
              Great! thanks alot steve.
