My Awesome Weathering Technique
    One of your better attempts at modelling Laurie - you are certainly improving. Try adding some decals to it! Don't forget to use a gloss varnish first though, otherwise you'll get the dreaded.........!
      Thanks Aidan I knew I could rely on you ! By the way it is a GRB Mk1AF6.
        I recognised it instantly Laurie! The aorodynamic prop shaft gives it away!
          Originally posted by \
          How about a Christmas special of building a swordfish and sticking them on our Christmas Tree? Afterall SWMBO can't argue its not a fairy!
          Like the idea Richard!
          That I call weathering Laurie!!!
          • Gern
            • 9306
            #20
            S
            Thanks Aidan I knew I could rely on you ! By the way it is a GRB Mk1AF6.Laurie
            Sorry to disagree Laurie, but this can't be the Mk1 prototype. The Mk1 had a pointed spinner, not the rounded one shown. This just has to be the early
            MkII - later MkII versions did have the rounded spinner, but all of those were fitted with Goodyear tyres and not the Dunlops that this one has.
            Gern
              Gern do not think you are right there. You are talking of the MK1 this one depicted here, the AF6, was a forerunner of the MK1
              The Galvanized Rust Bucket Company rolled this one out in 1877 or was it 1878. It did not have tyres & in fact only just got wheels the day before the maiden flight when they found that it had to take off.
              Rather sad it crashed as depicted in a bush. They discovered they had added to much to much rust & over loaded the frame. Later also discovered it was better to have a pilot.
              • Gern
                • 9306
                #22
                Gern do not think you are right there. You are talking of the MK1 this one depicted here, the AF6, was a forerunner of the MK1The Galvanized Rust Bucket Company rolled this one out in 1877 or was it 1878. It did not have tyres & in fact only just got wheels the day before the maiden flight when they found that it had to take off.
                Ooops! Just goes to show you can't always trust info you get from the web!
                Gern
                • mossiepilot
                  • Jul 2011
                  • 2272
                  #23
                  Just out of curiosity, is this the one with the steam powered Cayley rotary engine, can't see if it has the obligatory bucket for the coal fitted.
                  Tony.
