Sanders
    Sanders
    This may sound like a crazy question however there is a serious point to it....
    If a newcomer had £30 to spend on sanding materials, for plastic kits, and knew very little about the options and what to use, and when, what would you recommend please?
  • eddiesolo
    • Jul 2013
    • 11193
    I would get a Dremel type device. I use a Dremel for drilling, cutting and sanding, a grinding wheel set for shaping-plastic, wood etc, a cordless drill for drilling, sanding-wood using metal brushes-to create affects, also use loads of sanding paper-various and small modellers files.
    Si
      Originally posted by \
      I would get a Dremel type device. I use a Dremel for drilling, cutting and sanding, a grinding wheel set for shaping-plastic, wood etc, a cordless drill for drilling, sanding-wood using metal brushes-to create affects, also use loads of sanding paper-various and small modellers files.Si
      Hi SI
      Isn't a dremel somewhat fierce on plastic
        Aidan I would get a variety of sanding files of all gauges. Also the files with the foam in the middle sandwich. Also foam sandwich blocks which are very good for sanding & avoiding ridges when sanding roundish surfaces. The blocks are 30mm by 100mm. Used them with water.
        Also the Scobra pencil file. Like a propelling pencil. Turn the top & a fibre shaft appears. Good for cleaning up difficult to get into parts.
        Another Sanding needles.
        Yet another Micro pads.
        Flexi File. Best to have one for each grade of file tape. Very nice tool especially with all the different sanding tapes.
        Those are all I have found great but simple sanders.
        I fear "young man" that all your dosh has now dissipated into thin air. John I think stocks all these items.
        • eddiesolo
          • Jul 2013
          • 11193
          It depends on how you use it Aiden and on the size of the kit and what for. It can be a useful tool for helping in creating damage, or removing stubborn lips etc if you intend to modify. As Laurie points out there are many sanding forms from light use to heavy use. I actually forgot to mention sanding tapes and sanding needles-I have used both and find them good.
          Si
          • Gern
            • 9273
            Spend a few quid at the cosmetics counter in your local pound shop on all the sanding/filing things they stock for ladies' nails. There's emery boards and sanding sticks and sponges of all kinds with grades from very coarse down to fine polishing.
            A small set of needle files - similar to this:
            http://www.ebay.co.uk/itm/12-small-needle-files-160-mm-long-various-shapes-/370526690750?pt=UK_Hand_Tools_Equipment&hash=item5 6451c9dbe)
            A selection of wet and dry paper from Halfords - they do a pack containing one sheet of each of 240, 600, 800 and 1200 grit
            That should cover most of your needs. There are specialist sanding tools like micro files and flexi files and power tools like Dremels which are all useful but you'll go way over your budget getting sets of these. I'd only buy those if you find there are jobs you can't do with the basic stuff.
            Gern
            • yak face
              • Jun 2009
              • 14076
              • Tony
              I reckon dave (gern) has it covered , I too use a combination of wet and dry from halfords , sanding sticks and nail files . The assorted set available from the scale models shop is a good place to start http://www.scalemodelshop.co.uk/sand...-squ30506.html and e-bay can be a great source of nail files , these are what I use http://www.ebay.co.uk/itm/10-x-Premium-Straight-Nail-Files-Grits-80-100-80-180-100-150-100-180-180-180-/130798505831?pt=UK_Health_Beauty_Nails_Manicure_Pe dicure_CA&var=&hash=item64244436bf the dual grade 100/180 grit ones ., these 2 options combined with a pack of wet and dry from halfords should set you back well under £30 and is a good place to start from. cheers tony
                Thanks to all who replied.
                Laurie I cannot find a Scobra pencil file anywhere - it' sounds interesting.
                Tony the sanding stick value pack from Squadron tools - are these to be used wet?
                When does one use wet sanding please? I've never known this.
                  Wet sanding Aidan. Only use dry when there is a lot of plastic to get rid of.
                  Keep the surface wet all the time. Acts as a lubricant & you get a nice smooth finish perfect for the primer coat. I use a 1200/1500 grit for the final finish.
                    O dear fooled you on that one Aidan.
                    "Ecobra". http://cpc.farnell.com/1/1/1129-fibreglass-pencil-4mm-10191.html
                    Think you can get different diameters. Found they are good for getting into places other things will not.
                    • stona
                      • Jul 2008
                      • 9889
                      I use a selection of wet 'n' dry and files. Everything from a full size file for reducing resin to little needle files. I must have about thirty in different shapes and sizes. Apart from that a few polishing pads and sticks.
                      I do have a Dremel, nothing against them, but I rarely use it.
                      Drilling I invariably do by hand and have a set of pin vices that will accept bits from ludicrously small to about 2 or 3mm. Power drilling plastic seems a bit over the top, but whatever works for you
                        Thanks to all who replied.Laurie I cannot find a Scobra pencil file anywhere - it' sounds interesting.
                        Glassfibre Pencil http://www.select2gether.com/ecobra-glasradierer-760300.
                        http://www.ebay.de/itm/Glasfaserstift-Glasfaserradierer-Glasradierer-Polierstift-/190897200967?pt=Künstlerbedarf&hash=item2c725c1f47
                        Very good.
                        I used one for some filled wing roots. I also use chemist's nail emery boards (cheaper than modelling ones), but I use Flory's sanding and polishing sponge because, with its spongy layer under the abrasive, the curve of a model can be preserved rather than a flat sander leaving a flat. I also use various grades of "Wet and Dry" emery paper (used dry).
                          Laurie/Steve - what's the grade of these glass fibre pencils please? Are they course/medium/fine or is that a naive question?
                          Thanks
                            Laurie/Steve - what's the grade of these glass fibre pencils please? Are they course/medium/fine or is that a naive question?Thanks
                            Medium. I needed to smooth with Wet and Dry afterwards. If the glass fibres are poked out only a little way they are stiffer so act more coarsely; if poked out a greater amount, they have a softer action.
                            • Adrian "Marvel" Reynolds
                              • Apr 2012
                              • 3008
                              If I need to get a glass like finish I use Alclads Micromesh polishing cloth set, it has 3600, 4000, 6000, 8000 and 12,000 grade cloths with a foam rubber pad.
                              Adrian
