I have a problem and need help....
  • AlanG
    • 6296
    It appears that I have started getting Fw190itus syndrome. Is there a cure?
  • Adrian "Marvel" Reynolds
    • Apr 2012
    • 3008
    There is no cure, basically your Focke,,,,, sorry if that's a little near the knuckle but couldn't resist
    Adrian
      • 18302
      Sell some? LOL. (I'll relieve you of a D8 or 9 if you are thinning out)
      There is no other known cure.
        Looks like a bad case of OCD,Obsessive & Compulsive Disorder.
        But do not worry about it Allyne once you have built the lot you will be cured.
        However there can be set backs especially the SSS, Spitfire Shot up Syndrum. Particularly bad with the MK5 strain especially the early stages. Can lead to the worrying delibating effect of plastering glue on plastic.
        • flyjoe180
          • Jan 2012
          • 13085
          • Joe
          • Earth
          You make me feel better about my collection of kits. I'm not sure about the started getting Fw190itus syndrome bit, I think you may be well advanced.
          • Alan 45
            • Nov 2012
            • 9833
            I've heard of this afliction , but all is not lost ! There are two steps you can take to cure this terrible problem
            1, whenever you look at your stash of 190s put the radio on and listen to the archers after a week or two everytime you see 190s you will start humming the theme tune
            If that doesn't work then there is step two now this is quit frankly horrible if fac I'm thinking of it now and the thought of a 190 sends shivers down my spine.
            2, everytime you look at your 190s think of Gordon brown naked , f this fails then you are lost but let me tell you as I type this that image is in my mind and I don't think I can ever build a 190 !!!
            I hope this helps
              Don't you know you're supposed to call it "CDO"? Same thing, but in alphabetical order.
              • Gern
                • 9306
                Sadly Allyne there is no cure, but all is not lost, there is a form of therapy available to alleviate the symptoms.
                Step 1 Find a model of an FW 190 - any scale, manufacturer or marque that takes your fancy.
                Step 2 Build it.
                Step 3 If your affliction has not eased sufficiently, return to Step 1.
                Gern
                • yak face
                  • Jun 2009
                  • 14306
                  • Tony
                  The only cure i can think of Allyne is to go and build another kit , maybe your favourite aircraft or something , oh hang on...
                    I'd say it was ''obsessive collecting disorder'' ...
                    You want to try and subdue any further tendencies to collect more or soon you'll be sitting with others in a little circle saying things like ''my names Allyne and I'm a collecta-holic''
                    You can go ''cold turkey'' but I've heard scratch building aircraft out of white bird meat isn't the easiest thing to do
                      • 22983
                      I can't see any problem Allyne your not a Hypochondriac are you
                      • stona
                        • Jul 2008
                        • 9889
                        You could give some away to a good home
                        Only kidding, get some built, they are like Spitfires you can't have too many! Ever considered a few Bf 109s?
                          I think the only cure is:
                          Step 1 give swsbo your card
                          Step 2 methodically work your way through your problem
                          Step 3 post progress reports so all the model therapists on here can give encouragement until you have finished your treatment
                          Step 4 recover card from the above and hope the affliction does not return
                          • AlanG
                            • 6296
                            You could give some away to a good home Only kidding, get some built, they are like Spitfires you can't have too many! Ever considered a few Bf 109s?
                            I have a build for one of the Fw190 A8 kits to be converted to a Fw190 A8/R8 kit.
                            I also have six Bf109 kits to build (E, F, G and K)
                              Have you ever try the group therapy??
                              I still remember my first session....
                              -Hello, my name is Polux!
                              -Welcome Polux!!
                              -I have an addiction... I collect any kind of Land Rover kit...
                              -Ohhh!!! Don't worry, we are here to help you....
                              Three session after, all still the same... But is fun, and you meet people worst than you....
