Airbrushing?
    Just looked at the link alasdairs put up and that is what I have and it does what it's meant to. I havn't had any issues with it well none that has been the equipments fault
    • Alan 45
      • Nov 2012
      • 9833
      #17
      Cheers lads ill certainly take a look
      • colin m
        • 9064
        • Colin
        • Stafford, UK
        #18
        Originally posted by \
        I can see what you and Steve are saying it's just its a lot of money to lose if I'm no good at it, you see I'm not an impulsive person, oh I don't know what to do
        'No good at it' - I don't think any of us airbrush users were good at it straight from the off. I've been airbrushing for a few years and still have the 'pull your hair out moments' with the bl***y thing often. However, when you do get it right, well that's a nice feeling.
        • Alan 45
          • Nov 2012
          • 9833
          #19
          No seriously I will know if I'm good at after a few attempts , I can spray even coats that's not a problem I do sometimes spray undercoat it's things like camo and markings I'm thinking of to me there's no point in just doing your base coat by airbrush then doing camo by brush that's the skill I want to learn , it's like using pe on builds I'm trying it out now and it's not brilliant but I can improve on that
          • tanktrack
            • Jun 2012
            • 1429
            #20
            Hi Alan I use an as18-2 compressor that I bought off ebay and it cost £49 +p/p it has a moisture trap fitted and a pressure regulator which works for me , I have it connected to an iwata brush from John in the shop . the seller of the compressors is at http://myworld.ebay.co.uk/airbrushsupplyonline/&_trksid=p3984.m1439.l2754 has all sort of deals going with brush kits/compressors for sale so check it out, I starts with a cheap kit and it worked for me and as I got better I bought the more expensive one , there is an airbrush out there to suit your pocket , so give it a go and remember try and try again and don't give up .
            steve
              Alan I found the actual spraying bit OK. The bit that is more difficult is regulating the amount of paint you release at which distance. Also to see infinite progress in one session & find the curtains forming in the paint.
              Next keep the brush more than scruplously clean stir the paint & get the right consistency of paint by thinning. If you get this right you are a good way home.
              And another. Make sure that the part to be painted is free from grease & clean. I use a tack rag just before airbrushing which I lightly dust over the surface to pick up hairs.
              In short get the above right & it is nearly a "doddle". It is all simple stuff but needs all the above
              Every one who uses an airbrush will give out practice practice practice & much more practice.
              It is a challenge, I found, but as Colin says it is really worth all that & what you can do as seen by the experts. Go for it Alan as you will be very pleased.
              Just a thought. My opinion go for two stage brush with gravity feed. Started with one exactly the opposite single stage & the paint pot underneath the brush pulling the paint up. Complete frustration (for me).
                Have just seen a tank compressor with two airbrushes on eBay for under £70. Perhaps a good way to start? Here's the link
                This compressor looks exactly like the one that I bought in March (from somewhere else). It is excellent, and very popular with lots of sellers. The eBay deal includes a hose and two ABs. The price is good.
                My compressor came with a free AB which would have cost £16 separately. It was quite cheaply made but it worked OK for practicing on but after I had used it for a couple of months I got a much better one which was easier to clean and just better made but the cheaper one was useful for learning on. The larger of the two ABs has a 0.35 mm nozzle. Most advice here says to use a 0.4 mm size for a beginner because it blocks less easily (for example, if you haven't cleaned the AB after each use or not thinned the paint when it needed thinning). But 0.35 mm seems OK. Both have dual action which is good.
                The deal on eBay looks very good to me, if you have the £66.49. I would go for it, myself.
                Even with a compressor (compared to a gas can) airbrushing is a technique to be learned with practice. It took me a few months but, in some miraculous way, it just came together and I can reliably apply colour paint (I use acrylics) to produce a very good smooth finish (although varnish took longer to master). Thin the paint by about 10% to a "milk consistency", use about 20 PSI pressure from the compressor, pull the trigger back fully (or almost) and hold the AB about 9 inches from the model (or practice surface). Start the spray away from the part and keep spraying after you have made the last pass. This is to reduce sputtering which, (for me at least) tends to happen when the paint stream starts or stops. For colour (varnish is different) spray a light coat then when it has more-or-less dried, after 5 minutes (for acrylic) give a second then perhaps a third coat. Don't let a colour coat look wet. If it does, you have overdone it.
                  This compressor looks exactly like the one that I bought in ...........
                  I have just noticed that the AB with the jar (rather than the cup in the other one) has the larger nozzle (0.35). I have no experience of using an AB with a jar but I think it behaves like one with a cup.( I think the jar is used by people using a lot of paint at one time, more than a scale modeller would normally use.)
