Glue for PE parts ?
  • Alan 45
    • Nov 2012
    • 9833
    Glue for PE parts ?
    Hi folks is there a glue that is tacky enough to use on PE parts but not as quick drying as super glue ?
    At the moment I'm using a gel SG but it's drying too quickly in the thinned areas before I can get it into position
    Thanks
  • BarryW
    • Jul 2011
    • 6139
    I would use 'gator glue
    • Alan 45
      • Nov 2012
      • 9833
      Originally posted by \
      Thanks Barry ill order some today
        Go with Barry,Alan, very versatile glue. Great thing is while still in liquid form it can be wiped away with water.
        It is also a gap filler as it expands as it cures an advantage but also if not careful a disadvantage as it will move your pieces if you plaster it on unless restrained.
        So I just use a very minimum amount. Sticks like industrial velcro.
        On the PE parts I use super duper glue but the Loctite gel type which is slower to go off. When all is positioned with a "third hand", I wish, I give a small drop of accelerator
        Matter of interest the gel type is good where you have wireless antennae & need to represent a join where they have used a rigging joint. A blob of super glue (Cyanoacrylate or CA) gives a good representation.
        • Alan 45
          • Nov 2012
          • 9833
          Go with Barry,Alan, very versatile glue. Great thing is while still in liquid form it can be wiped away with water.It is also a gap filler as it expands as it cures an advantage but also if not careful a disadvantage as it will move your pieces if you plaster it on unless restrained.
          Thanks Laurie I'm going to my local hobby shop today to see if he's got either of these as the shop is out of stock
          Thanks for your input
          • John
            • Mar 2004
            • 4700
            • John
            • Halifax
            The guy that makes Gator glue stopped making it in April, he apparently had a large DIY project he wanted to do, I emailed him last night and he's going to make a batch for me, not sure when I will have it in, best guess is 3-4 weeks, if you can't wait that long a good alternative is Kristal Klear
            www.scalemodelshop.co.uk
              John there is an alternative which is called Gorilla Glue. Seems to do the same trick.
              • Alan 45
                • Nov 2012
                • 9833
                Thanks John ill get some then in the meantime I've got some poly-zap from my local the bloke in the shop I use told me its as good as
                • John
                  • Mar 2004
                  • 4700
                  • John
                  • Halifax
                  John there is an alternative which is called Gorilla Glue. Seems to do the same trick.Laurie
                  Does it still dry clear? it doesn't seem as safe as Gator glue
                  Warning: Irritating to eyes, respiratory system and skin. Keep locked up and out of the reach of children.
                    John. Looking at the ring of Gorilla glue left around the lid it looks the same as Gaytor. Also has the same smell. Think that both cure with a slight fawn appearance.
                    So have put a sample of each on plastic & will do a SITREP.
                    Instructions for use are the same expansion & secure pieces etc. Would think the precautions belong to both glues but Gorilla have use & hazard publications. Can not find any for Gaytor.
                    I was sceptical about it, suppose the name, when I bought it. The container & application nozzle are much better than the Gaytor.
                      John these sites give the details
                      http://www.gorillaglue.com/LinkClick.aspx?fileticket=tWHGr3zYQNY%3D&tabid=95
                      http://www.everbuild.co.uk/image/data/MSDS%20Adhesives/Gator%20Glue.pdf
                      Looks as though both are made with the same constituents & act in the same way. Both have similar hazard warnings.
                      Gaytor from the results of my high class lab. experiments show that Gaytor goes off a little quicker & also foams or expands more. Both are a slighty transparent fawn in colour.
                      • John
                        • Mar 2004
                        • 4700
                        • John
                        • Halifax
                        Thanks Laurie, was curious to see how it compares with gator glue. The data sheet you have linked to isn't the same gator glue as I stock.
                          The stuff I have is marketed by Everbuilding Products. It has a green Crocodile on the label.
                            • 18302
                            I think the gator glue you have found Laurie is some thing quite different to the Gator's Grip glue for model builders.
                            The one you refer to is a builders glue.
                            Her is a review of the 'correct' one. http://www.aeroscale.co.uk/modules.php?op=modload&name=Reviews&file=index&req =showcontent&id=5618
                            My doubts were aroused when you wrote that gator glue expands. I use it a lot and it has never expanded. Apart from carpentry a glue that expands is as useful as a saw with out teeth!
                              • 18302
                              In that case I would like to put my name on a couple of those gator'e grip pots when you get them in.
