lighting....
    lighting....
    The years seem to be catching me up and my eyes are not what they were.
    I more or less gave up modelling with frustration as my efforts were not very good.
    It wasn't until recently I realised I needed glasses and things have improved slightly.
    But with dark nights coming I need better lighting than my energy saving overhead bulbs.
    Ive been looking at my local model shop EMODELS. And what they have to offer. But 75 quid for a lamp and magnifier?
    What lighting is used by everyone else? Any recommendations?
    A little strip light above the bench and some cabinet spotlights that I've fixed clips to so they can be positioned almost anywhere.
    I had a pair of pescription glasses made with a 10/11 inch focal point ... Much closer focus than normal reading distance.
    • John
      • Mar 2004
      • 4700
      • John
      • Halifax
      If your using fluorescent or led get daylight (colour 860) go to your local electrical wholesaler don't pay model shop prices, ask for trade prices most will give you the discount a 2ft tube should only cost a couple of quid, the fitting will cost a little more.
      Just a note if you are buying a new fitting get HF which is high frequency you won't get that annoying flicker, the tubes last longer and cheaper to run.
      www.scalemodelshop.co.uk
        Forgot to say that I use a reptile tube so that is virtually daylight in its spectrum.
        • John
          • Mar 2004
          • 4700
          • John
          • Halifax
          Handy for vitamin d but not the same as daylight tubes, you will find they range between 5500-6500k and considerably dearer
            I have an 11 watt fluorescent desk lamp with a double arm "Anglepoise" mechanism that a friend gave me years ago. I can put its lamp close to the work.
            But the best buy I have made is the following headband magnifier. It leaves the hands free:
            http://www.expotools.com/cgi-bin/sh000001.pl?WD=magnifier&PN=Headband%2dMagnifier%2 dwith%2d3%2dlenses%2d73840%2ehtml#SID=68
            It is good quality and, using my reading glasses and one or both of the main lenses, allows items to be held in focus with both eyes at 9 or 6 inches distance, or down to 4 1/2 inches with the single glass stage in use. The main two lenses are plastic and also, I think, the single "glass", but that's no problem. I wish I had bought it years ago.
            [ATTACH]70211.IPB[/ATTACH]
            Price: £16.95 (Including VAT at 20%)
            738-40 Headband Magnifier
            with 3 lenses.
            Features 3 seperate lenses, all
            contained within the unit, which
            enables the user to quickly switch
            between four different
            magnification strengths.
            4 Different magnification strengths:
            LENS A only: 1.8x
            LENS A + B together: 2.3x
            LENS A + C together: 3.7x
            LENS A + B + C together: 4.8x.
            Velcro adjustable
            headstrap fits all
            sizes.
            Lens B is hinged &
            sprung -and can be
            clipped in position
            behind Lens A when
            required.
              Not the vitamin d type, our animals are mainly nocturnal so dont need the extra lighting vitamins, we subsidise that with vitamin powder etc. The tube I use is TL84 which gives a daylight tone to display colours ... TL84 was a standard that M&S adopted to colour match their fabrics in a light box ... I happened to come across a few (ahem) when I worked at the dyehouse.
              I found that the tubes that are sold for enhancing the colours of fish and reptiles (as you say... Hellish expensive) are the same type of tube.
