The build calendar for 2014
    • 18301
    I hope that this works for you all, that is a bit of a big hope but I am sure that for the most it will be OK. I have tried to plan it so there are no two Group build or Themed build that are the same genre.
    As far as shopping lists go its fine here and now. If there is a VERY good reason to swap dates around you had better get in quick!
    [ATTACH]72145.IPB[/ATTACH]
    Excellent calendar Ian.
    I like very much the SIG distribution, one month of time between each build!
    Regards
      Works for me.
      Thanks for putting it all together mate.
      • spanner570
        • 15599
        Super job Ian.
        Thanks so much for putting all this together, avoiding the flak, answering questions, tolerating the good hearted banter, and coming up with an excellent choice of builds.
        Top marks.
        Now sit back for 12 months and let the fun begin!
        Ron
          • 18301
          Well I'm more than glad with the feed back so far. Thanks Chaps.
          If you can I would suggest that you print the calendar out and stick it on the wall by the bench...
            Ive just downloaded it and am using it as my PC wallpaper in my little modeling room.
            • Dave W
              • Jan 2011
              • 4713
              Looks like some good builds to do .I will Definately be doing the Lighning,Harrier,FAA and WW1 builds
              • Richi72
                • Sep 2013
                • 1100
                Super Ian,
                thanks allot i think i will join Arnheim it,s got a good deadline to keep up with :P :P
                  • 18301
                  I'm good for the Frightening and I even have a Harriet... A valentine tja, got a couple in the stash... Sherman.... Maybe, I have a Lee. I might even have a go at a Mini....
                  Oh then theres that blasted boat!!! I gunna be busy...
                    • 22948
                    Well that looks very good Ian. A job well done on the chart, but in the SIG build the bottom green line is empty should there be a build from July ?
                    • PaulTRose
                      • Jun 2013
                      • 7084
                      • Tattooine
                      works for me too
                      a few there im interested in, a few im not so a good mix
                      *goes to check stash*
                      Per Ardua
                        • 18301
                        Erm Wiggle room? I have not missed one, but it could be some thing turns up...
                        • rickoshea52
                          • Dec 2011
                          • 4080
                          • Rick
                          I had a quick rummage through my stash to see what I already had that would fit in to this calendar. I think I am quite well prepared to do some or all with regards to kits. Time is the commodity I lack though.
                          [ATTACH]72336.IPB[/ATTACH]
                          [ATTACH]72337.IPB[/ATTACH]
                          [ATTACH]72338.IPB[/ATTACH]
                          [ATTACH]72339.IPB[/ATTACH]
                          [ATTACH]72340.IPB[/ATTACH]
                          [ATTACH]72341.IPB[/ATTACH]
                            Looks good, just got to look in the stash now..
                            • colin m
                              • 9019
                              • Colin
                              • Stafford, UK
                              Thanks for that Ian, loads to choose from. Infact, I'm not sure I'll be able to do everything I want to !
