hot knife ?
  • monica
    • Oct 2013
    • 15169
    hot knife ?
    hi i was wondering if you can get a heated bladed hobby knife ?
    as if i need to open a hatch or door on a model , i use a fine blade heated
    over the gas burner on the stove to cut the bit out, but was thinking surly
    there, must be a better way off doing it so you don't lose about 2 to 3 mm
    off each side
    Moni
  • AlanG
    • 6296
    Chain drill it out with a 0.5mm drill
      • 18302
      You can also buy a very fine bladed fretsaw that can be used to cut holes. You will need to drill a small hole to pass the blade through but it works well.
      If you have a steady hand you could also use a panel line cutter or P cutter and scratch the panel line right through. I some times just use a scalpel but mine the fingers, they are a lot easier to cut than plastic.
      Another good trick is good old cotton thread. I use it some times to cut flaps and rudders off aircraft kits.
      • monica
        • Oct 2013
        • 15169
        hi Lan M / Allyne
        yes both good ways around it , as there is so meany little tools i need to get like i think its called a pin vice
        or hand brill for fine drill bits, razes saw, and a few others things
        oh yes i have had a scalpel right through my fingers a few times trying to scratch out the line ,that why i
        tried the hot blade
        i have never herd off that way with the cotton thread so it acts like a saw ?
        thanks guys
        mONI
        • Gern
          • 9306
          Don't know whether you can get these 'down under' but some sort of attachment like this for a soldering iron might be what you want:
          http://cpc.farnell.com/1/1/6433-hot-knife-blade-chuck-hk11-weller.html
          Have to be careful melting plastic though as some of them give off some very nasty fumes.
          Gern
          • Richi72
            • Sep 2013
            • 1100
            Hi Moni, I found this guy a couple of years ago, he has a nice range of saw blades and other useful tools. serves is good to. Hope this helps a little.
            Link
            cheers Richi
              The best way I have found is with a razor blade. The American type with a thick backing one edge the other the blade.
              The blades are half that of the Morton Knives and are very sharp. Just scribe lightly around the object repeating with more weight each time. You get a very nice cut & if the piece to be cut out is still to be used there is no damage if carefully done with patience.
              Problem with a hot knife it will distort the plastic.
              This American blade has lots of uses cutting tape on canopies as one.
              • stona
                • Jul 2008
                • 9889
                Originally posted by \
                Hi Moni, I found this guy a couple of years ago, he has a nice range of saw blades and other useful tools. serves is good to. Hope this helps a little.Link
                cheers Richi
                I get some bits from Radu including his razor saws. Very good, but you will need your own handle.
                • Richi72
                  • Sep 2013
                  • 1100
                  I get some bits from Radu including his razor saws. Very good, but you will need your own handle.Cheers
                  Hi Steve, he sells Handles too at the end of the page. but most of us have probable handles.
                  Cheers Richi
                  • stona
                    • Jul 2008
                    • 9889
                    Thanks Richi, I never looked on the RB site for handles so it's good to know they are there.
                    Here's a picture of one of the RB fine razor saws (he does an ultra fine too IIRC) assembled and in a handle above a standard Tamiya razor saw. I hope you can see how much finer the RB saw is.
                    • monica
                      • Oct 2013
                      • 15169
                      hi all thats great help thank you all very much , plus the links ,as you get to a point and just need a better tool kit
                      and the cheap tools for the two dollar shop just are not worth it ,and after having blades in the fingers a few times
                      well,the pic is real clear and shows both saws, have not seen these The American type razor blades in yrs,
                      the other thing or problem is cutting pop sticks ,as the wood is so hard and have had a few close ones with them
                      whats a good way off cutting them length ways plz,ever i score down them adding a little more presser they just
                      dont wont to cut , then you slip and put the Stanly knive into your hand
                      Moni
                      [ATTACH]75739.IPB[/ATTACH]
                        For me the best way is make a hole with a drill and then cut with a jewellers saw
                        • monica
                          • Oct 2013
                          • 15169
                          hi, that would work as well there just nasty hard things, i was also thing off using a big chisel or wide one
                          to slit them ,
